Aller au contenu principal
Lumen Projector Bulb Replacement
Ce dont vous avez besoin
  1. Lumen Projector Bulb Replacement, Unplug projector: étape 1, image 1 de 1
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Lumen Projector Bulb Replacement: étape 2, image 1 de 1
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Lumen Projector Bulb Replacement: étape 3, image 1 de 1
    • Unscrew the bulb screws on either side of the silver plate.
  4. Lumen Projector Bulb Replacement: étape 4, image 1 de 1
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Lumen Projector Bulb Replacement: étape 5, image 1 de 1
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Lumen Projector Bulb Replacement: étape 6, image 1 de 1
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Lumen Projector Bulb Replacement: étape 7, image 1 de 1
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Lumen Projector Bulb Replacement: étape 8, image 1 de 1
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Lumen Projector Bulb Replacement: étape 9, image 1 de 1
    • Dispose of the bulb by sending it to a recycling center.
Desiree Benitez
Membre depuis le 01/21/17
128 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 Membre de l'équipe USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017
USFSM-STEWART-S17S1G1
19 membres
19 tutoriels rédigés
Un commentaire
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 761
