Aller au contenu principal
M3D Micro Nozzle Replacement
Ce dont vous avez besoin
  1. M3D Micro Nozzle Replacement, Fan: étape 1, image 1 de 3 M3D Micro Nozzle Replacement, Fan: étape 1, image 2 de 3 M3D Micro Nozzle Replacement, Fan: étape 1, image 3 de 3
    • To release the x-rods, pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks.
  2. M3D Micro Nozzle Replacement: étape 2, image 1 de 3 M3D Micro Nozzle Replacement: étape 2, image 2 de 3 M3D Micro Nozzle Replacement: étape 2, image 3 de 3
    • Slide the tracks off the second slider and remove the printer head and x-tracks from the center of the printer. To remove the front cover of the print head, firmly grip the cover and gently pull it off.
  3. M3D Micro Nozzle Replacement: étape 3, image 1 de 2 M3D Micro Nozzle Replacement: étape 3, image 2 de 2
    • Disconnect the red and black wires at the white connector. They should easily separate.
  4. M3D Micro Nozzle Replacement: étape 4, image 1 de 3 M3D Micro Nozzle Replacement: étape 4, image 2 de 3 M3D Micro Nozzle Replacement: étape 4, image 3 de 3
    • The fan is held loosely in place at the base of the printer head. Use a metal spudger to gently pry it out of the printer head.
  5. M3D Micro Nozzle Replacement: étape 5, image 1 de 1
    • Pull the fan all the way out of the printer head.
  6. M3D Micro Nozzle Replacement, Nozzle: étape 6, image 1 de 2 M3D Micro Nozzle Replacement, Nozzle: étape 6, image 2 de 2
    • To remove the nozzle insulation, grip the insulation and pull it up off of the nozzle.
  7. M3D Micro Nozzle Replacement: étape 7, image 1 de 2 M3D Micro Nozzle Replacement: étape 7, image 2 de 2
    • To remove the nozzle, use a 5 mm nut driver to unscrew it.
3 autres ont terminé cette réparation.
Yuliya Marusyk
Membre depuis le 09/28/17
282 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S3-G2, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 24
Total : 2,698
