Aller au contenu principal
MAGNAVOX MDV2300 Power Cord Replacement
Ce dont vous avez besoin
  1. MAGNAVOX MDV2300 Power Cord Replacement, Power Cord: étape 1, image 1 de 1
    • Make sure the device is unplugged from the wall.
  2. MAGNAVOX MDV2300 Power Cord Replacement: étape 2, image 1 de 1
    • Unscrew the two screws that hold together the top panel.
  3. MAGNAVOX MDV2300 Power Cord Replacement: étape 3, image 1 de 1
    • Remove the top panel.
  4. MAGNAVOX MDV2300 Power Cord Replacement: étape 4, image 1 de 1
  5. MAGNAVOX MDV2300 Power Cord Replacement: étape 5, image 1 de 2 MAGNAVOX MDV2300 Power Cord Replacement: étape 5, image 2 de 2
    • Remove disc drive by unscrewing the 2 screws that hold the drive in place.
  6. MAGNAVOX MDV2300 Power Cord Replacement: étape 6, image 1 de 1
    • Identify the power cord.
    • The cord must either be too short or torn to warrant replacement.
  7. MAGNAVOX MDV2300 Power Cord Replacement: étape 7, image 1 de 1
    • Cut the old wire out from the chip.
    • Attach the new wire into the housing.
    • Line up new wire with the appropriate holes and solder to board.
    • The white wire will be your neutral and the black wire will be your negative. View link of how to solder in order to replace the power cord. http://www.instructables.com/id/How-to-s...
After soldering, let cool and then reassemble your device, follow these instructions in reverse order.
Justin
Membre depuis le 01/21/15
298 Réputation
2 tutoriels rédigés
Équipe
Penn State, Team 1-41, Kaschak Winter 2015 Membre de l'équipe Penn State, Team 1-41, Kaschak Winter 2015
PSU-KASCHAK-W15S1G41
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 522
