Introduction
MNT Reform has two identical battery boards. Each board has four 18650 cells with LiFePO4 chemistry (3.2V). Only use LiFePO4 cells with MNT Reform! Other chemistries, like Li-Ion or NiMH are incompatible.
Ce dont vous avez besoin
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
Pull out the eight battery cells one by one, and set them aside safely.
Unplug the battery pack cables from the BATLEFT and BATRIGHT sockets on the motherboard.
Remove the following screws securing the left battery board to the main box:
Four M2×4 pan head Philips screws
Remove the following screws securing the right battery board to the main box:
If you are installing new boards, unplug the battery cables from your old boards.
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don't overtighten screws.
