Aller au contenu principal
MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement
Ce dont vous avez besoin
  1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement, Faucet: étape 1, image 1 de 1
    • Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
  2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 2, image 1 de 1
    • Turn the tap(s) on to release any pressure build-up in the pipes.
  3. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 3, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 3, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 3, image 3 de 3
    • With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
  4. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 4, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 4, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 4, image 3 de 3
    • With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
    • After unscrewing the bolts, the faucet pipes should easily come off.
  5. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 5, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 5, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 5, image 3 de 3
    • Disconnect the lift rod for the drain plug by pushing it off the metal rod.
  6. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 6, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 6, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 6, image 3 de 3
    • After everything is completely disconnected, pull the faucet out from the top.
  7. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 7, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 7, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 7, image 3 de 3
    • Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
  8. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 8, image 1 de 2 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 8, image 2 de 2
    • Insert the pipes of the replacement faucet through the sink holes.
    • Each pipe will correspond to each hole on the right and left.
  9. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 9, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 9, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 9, image 3 de 3
    • With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
  10. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 10, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 10, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 10, image 3 de 3
    • Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
    • Tighten the left and the right pipe.
  11. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 11, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 11, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 11, image 3 de 3
    • Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
  12. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 12, image 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 12, image 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 12, image 3 de 3
    • Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
  13. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: étape 13, image 1 de 1
    • Turn on the tap and inspect for leakage. If any leakage does appear, refer to step 1 & 10 and make the pipe bolts tighter.
    • Otherwise, the replacement sink is completely installed.
To remove the replacement faucet, follow steps 1-6.
Manahal Khalil
Membre depuis le 09/11/21
217 Réputation
1 tutoriel rédigé
Équipe
York University, Team E-9, Melo-Thaiss Fall 2021 Membre de l'équipe York University, Team E-9, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG9
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 38
Total : 864
