Aller au contenu principal
MSI GE62 6QF Apache Pro Battery Replacement
Ce dont vous avez besoin
  1. MSI GE62 6QF Apache Pro Battery Replacement, Optical Drive: étape 1, image 1 de 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Battery Replacement: étape 2, image 1 de 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Battery Replacement, Bottom Case: étape 3, image 1 de 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Battery Replacement: étape 4, image 1 de 3 MSI GE62 6QF Apache Pro Battery Replacement: étape 4, image 2 de 3 MSI GE62 6QF Apache Pro Battery Replacement: étape 4, image 3 de 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Battery Replacement: étape 5, image 1 de 2 MSI GE62 6QF Apache Pro Battery Replacement: étape 5, image 2 de 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Battery Replacement, Battery: étape 6, image 1 de 3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: étape 6, image 2 de 3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: étape 6, image 3 de 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
4 autres ont terminé cette réparation.
Justice Owens
Membre depuis le 09/26/17
604 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S2-G3, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 membres
5 tutoriels rédigés
Un commentaire
Excellent guide! Very straightforward with very clear picture. I was able to replace my laptop battery using your tools and following your instruction! 10/10!
Carl Patterson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 45
Total : 6,386
