Aller au contenu principal
MSI GE62 6QF Apache Pro Hard Drive Replacement
Ce dont vous avez besoin
  1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Optical Drive: étape 1, image 1 de 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Hard Drive Replacement: étape 2, image 1 de 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Hard Drive Replacement, Bottom Case: étape 3, image 1 de 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Hard Drive Replacement: étape 4, image 1 de 3 MSI GE62 6QF Apache Pro Hard Drive Replacement: étape 4, image 2 de 3 MSI GE62 6QF Apache Pro Hard Drive Replacement: étape 4, image 3 de 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Hard Drive Replacement: étape 5, image 1 de 2 MSI GE62 6QF Apache Pro Hard Drive Replacement: étape 5, image 2 de 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: étape 6, image 1 de 3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: étape 6, image 2 de 3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: étape 6, image 3 de 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: étape 7, image 1 de 3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: étape 7, image 2 de 3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: étape 7, image 3 de 3
    • Unscrew the two black PH #0 2mm screws holding the lower part the hard drive plate
    • Unscrew the two PH #0 4mm screws holding the upper part of the hard drive plate
  8. MSI GE62 6QF Apache Pro Hard Drive Replacement: étape 8, image 1 de 2 MSI GE62 6QF Apache Pro Hard Drive Replacement: étape 8, image 2 de 2
    • Remove the hard drive by gently lifting up and pulling the drive out of the connection slot
5 autres ont terminé cette réparation.
Justice Owens
Membre depuis le 09/26/17
604 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S2-G3, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 membres
5 tutoriels rédigés
4 commentaires
Saved my life, would have had no idea what to do without these instructions and would probably have broke something. My new 2tb ssd is working fine
Simon Porter - Réponse
Upgraded the Memory to 32GB and the HDD to a 1TB SATA SSD.
Prabodha Elangasinha - Réponse
Only issue I ran into was one of the optical drive screws was frozen in, stripped hard, and I had to fall back on Moodys to break it loose. Once done, everything else was cake.
Chuck Brewer - Réponse
My ssd is working fine and the hdd has gone bad on mine... have not even opened mine yet but looking at the pics I wonder where the second drive is located?
Eric Jimenez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 43
Total : 8,350
