Aller au contenu principal
MSI GE62 7RD RAM Replacement
Ce dont vous avez besoin
  1. MSI GE62 7RD RAM Replacement, RAM: étape 1, image 1 de 1
    • Flip the laptop over so that the bottom is on top.
    • Caution: make sure the laptop is fully powered off (not sleep mode) and not connected to the AC charging adapter before beginning the repair.
  2. MSI GE62 7RD RAM Replacement: étape 2, image 1 de 2 MSI GE62 7RD RAM Replacement: étape 2, image 2 de 2
    • Remove the fifteen 6.5 mm Phillips #0 screws from the bottom of the laptop using a Phillips #0 screwdriver.
    • Be sure to remove the two screws in the middle of the laptop, they're easy to miss! They might be under a factory seal label.
  3. MSI GE62 7RD RAM Replacement: étape 3, image 1 de 2 MSI GE62 7RD RAM Replacement: étape 3, image 2 de 2
    • Remove the back case from the laptop.
    • If the backing is really stuck, you may use a plastic opening tool or picks to provide leverage.
  4. MSI GE62 7RD RAM Replacement: étape 4, image 1 de 2 MSI GE62 7RD RAM Replacement: étape 4, image 2 de 2
    • With both thumbs, pull the silver overhangs on the sides of the RAM until the old stick of RAM pops up.
  5. MSI GE62 7RD RAM Replacement: étape 5, image 1 de 1
    • Remove the old stick of RAM by pulling back and out.
  6. MSI GE62 7RD RAM Replacement: étape 6, image 1 de 2 MSI GE62 7RD RAM Replacement: étape 6, image 2 de 2
    • Place the new stick of RAM in the socket so that the electrical contacts match.
    • Push the top of the stick of RAM down and in until you hear the click of the silver overhangs latch onto the RAM.
William Guyton
Membre depuis le 10/10/20
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 23
Total : 855
