Introduction
This guide will show how to replace the motherboard on the MSI Apache Pro 004 laptop.
Pièces
Aucune pièce nécessaire.
Start with the bottom of the laptop facing up.
  • Start with the bottom of the laptop facing up.
Ajouter un commentaire
Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
  • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
  • Remove the bottom plate
  • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  • Remove the screw holding down the battery with a PH1 screwdriver.
  • Pull out the battery.
  • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
  • Unfasten the 8 screws holding the motherboard in place.
  • Pull out the motherboard.
Alexander
Membre depuis le 19/02/2018
86 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S15-G5, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 53
Total : 162
