Aller au contenu principal
MSI GE62 Apache Pro 004 Speakers Replacement
Ce dont vous avez besoin
  1. MSI GE62 Apache Pro 004 Speakers Replacement, Battery: étape 1, image 1 de 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Speakers Replacement: étape 2, image 1 de 2 MSI GE62 Apache Pro 004 Speakers Replacement: étape 2, image 2 de 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Speakers Replacement: étape 3, image 1 de 3 MSI GE62 Apache Pro 004 Speakers Replacement: étape 3, image 2 de 3 MSI GE62 Apache Pro 004 Speakers Replacement: étape 3, image 3 de 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: étape 4, image 1 de 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: étape 4, image 2 de 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: étape 4, image 3 de 3
    • Remove the four screws, two on each speaker, with a PH1 screwdriver.
  5. MSI GE62 Apache Pro 004 Speakers Replacement: étape 5, image 1 de 2 MSI GE62 Apache Pro 004 Speakers Replacement: étape 5, image 2 de 2
    • Gently pull back the speakers until they release from their socket.
    • Keep track of which speaker went where. The connectors for the speakers are unique; you cannot use a speaker that should go on the right side on the left side and vice versa.
Majid Al Hashmi
Membre depuis le 02/13/18
283 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S15-G5, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 1,521
