Aller au contenu principal
MSI GE72 6QF Apache Pro Optical Drive Replacement
Ce dont vous avez besoin
  1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: étape 1, image 1 de 2 MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: étape 1, image 2 de 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Optical Drive Replacement: étape 2, image 1 de 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Optical Drive Replacement: étape 3, image 1 de 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Optical Drive Replacement: étape 4, image 1 de 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: étape 4, image 2 de 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Optical Drive Replacement: étape 5, image 1 de 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: étape 5, image 2 de 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Optical Drive Replacement: étape 6, image 1 de 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: étape 6, image 2 de 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: étape 7, image 1 de 3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: étape 7, image 2 de 3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: étape 7, image 3 de 3
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
Riley Smith
Membre depuis le 09/22/17
806 Réputation
4 tutoriels rédigés
2 commentaires
Why do you have to remove the battery first?
Kevin - Réponse
So you don’t have power running through it while working on it.
croberts1290 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 1,463
