Aller au contenu principal
MSI GP60 2PE Leopard Wireless Card Replacement
Ce dont vous avez besoin
  1. MSI GP60 2PE Leopard Wireless Card Replacement, Battery: étape 1, image 1 de 1
    • Flip MSI GP60 2PE Leopard, so that the back is facing up.
  2. MSI GP60 2PE Leopard Wireless Card Replacement: étape 2, image 1 de 1
    • Find the unlock tab located on the upper right side of the device, then slide it to the right.
  3. MSI GP60 2PE Leopard Wireless Card Replacement: étape 3, image 1 de 3 MSI GP60 2PE Leopard Wireless Card Replacement: étape 3, image 2 de 3 MSI GP60 2PE Leopard Wireless Card Replacement: étape 3, image 3 de 3
    • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
  4. MSI GP60 2PE Leopard Wireless Card Replacement: étape 4, image 1 de 3 MSI GP60 2PE Leopard Wireless Card Replacement: étape 4, image 2 de 3 MSI GP60 2PE Leopard Wireless Card Replacement: étape 4, image 3 de 3
    • While holding the release tab, remove the battery slowly.
  5. MSI GP60 2PE Leopard Wireless Card Replacement, Back Panel: étape 5, image 1 de 1
    • Flip the device over so the back is facing up.
  6. MSI GP60 2PE Leopard Wireless Card Replacement: étape 6, image 1 de 2 MSI GP60 2PE Leopard Wireless Card Replacement: étape 6, image 2 de 2
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  7. MSI GP60 2PE Leopard Wireless Card Replacement: étape 7, image 1 de 2 MSI GP60 2PE Leopard Wireless Card Replacement: étape 7, image 2 de 2
    • Once all four screws are removed, lift the back off.
  8. MSI GP60 2PE Leopard Wireless Card Replacement, Wireless Card: étape 8, image 1 de 1
    • Locate the wireless card.
  9. MSI GP60 2PE Leopard Wireless Card Replacement: étape 9, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the one 2 mm screw that is holding the wireless card in place.
  10. MSI GP60 2PE Leopard Wireless Card Replacement: étape 10, image 1 de 1
    • Carefully remove the wireless card.
    • Pay close attention to the two wires attached to wireless card.
  11. MSI GP60 2PE Leopard Wireless Card Replacement: étape 11, image 1 de 2 MSI GP60 2PE Leopard Wireless Card Replacement: étape 11, image 2 de 2
    • Remove the wires connecting to the wireless card by pinching around the base where they connect, then carefully disconnect them.
    • The wires should come off fairly easily.
    • Avoid yanking or pulling too hard. This can result in the wires breaking.
2 autres ont terminé cette réparation.
Zoey Calcagno
Membre depuis le 10/04/18
672 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 24
Total : 1,335
