Aller au contenu principal
MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement
Ce dont vous avez besoin
  1. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: étape 1, image 1 de 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: étape 1, image 2 de 2
    • Using the Jimmy tool, pry the front cover off at the seam.
    • The Jimmy tool is the utensil in the first picture in the user's hand.
  2. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: étape 2, image 1 de 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: étape 2, image 2 de 2
    • Remove the four 2 mm screws on the bottom and top corners of the screen using a Phillips #0 screwdriver.
  3. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: étape 3, image 1 de 1
    • Using the Jimmy, pry off the unscrewed LCD display.
    • Make sure the black adhesive is out of the way.
    • Don't pull the screen completely off, as the screen will still be attached.
  4. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: étape 4, image 1 de 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: étape 4, image 2 de 2
    • Remove the ribbon cable by pulling on the bar code tab.
3 commentaires
Hey Jordan, when reassembling the front cover (which in my case, a GP63 Leopard 8RE, is glued at the bottom) what type of glue should be used? Thanks
Jaime Blasco - Réponse
Hi Jaime, two part expoxy (Alraldite) glue should work, otherwise 3M double-sided adhesive tape would work as well.
Jordan Buck -
Hi Jordan,
If the screen is damaged due to the cover itself being bent, do you have any advice?
Thanks
Ainsley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 31
Total : 1,335
