Aller au contenu principal
MSI GS66 Stealth 11UE-007 Cooling Fan Replacement
Ce dont vous avez besoin
  1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: étape 1, image 1 de 1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device for any outlet.
  2. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 2, image 1 de 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 2, image 2 de 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 2, image 3 de 3
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
    • Remove eight 10mm Phillips J1 screws.
    • Remove one 7mm Philips J1 screw from the center bottom of backplate.
  3. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 3, image 1 de 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 3, image 2 de 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 3, image 3 de 3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  4. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 4, image 1 de 2 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 4, image 2 de 2
    • Disconnect the wires from the cooling fan.
  5. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 5, image 1 de 2 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 5, image 2 de 2
    • Disconnect the two wires from the Wi-Fi card.
  6. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 6, image 1 de 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 6, image 2 de 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 6, image 3 de 3
    • Remove the nine 6 mm screws.
  7. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 7, image 1 de 2 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 7, image 2 de 2
    • Remove the tape connecting the fans to the fan housing.
  8. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: étape 8, image 1 de 1
    • Lift up the cooling unit like it is hinged at the back.
    • Replace thermal paste.
  9. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: étape 9, image 1 de 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: étape 9, image 2 de 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: étape 9, image 3 de 3
    • Remove the fans
4 autres ont terminé cette réparation.
Alex Robinson
Membre depuis le 09/06/23
1 057 Réputation
6 tutoriels rédigés
Équipe
University of Memphis, Team 1-4, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-4, Sneed Fall 2023
UM-SNEED-F23S1G4
4 membres
6 tutoriels rédigés
Un commentaire
Has anyone found a solution to this issue yet, that doesn't require micro soldering`````````````Jorge Rodriguez.
Rachel Kelley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 23
30 derniers jours : 106
Total : 717
