Aller au contenu principal
MSI GT62VR 6RD Dominator Battery Replacement
Ce dont vous avez besoin
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: étape 1, image 1 de 2 MSI GT62VR 6RD Dominator Battery Replacement, Battery: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: étape 2, image 1 de 2 MSI GT62VR 6RD Dominator Battery Replacement: étape 2, image 2 de 2
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: étape 3, image 1 de 3 MSI GT62VR 6RD Dominator Battery Replacement: étape 3, image 2 de 3 MSI GT62VR 6RD Dominator Battery Replacement: étape 3, image 3 de 3
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
Rebekah Johnson
Membre depuis le 09/18/18
147 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 23
Total : 1,920
