Aller au contenu principal
MSI GT62VR 6RD Dominator M.2 SSD Replacement
Ce dont vous avez besoin
  1. MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: étape 1, image 1 de 2 MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: étape 1, image 2 de 2
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator M.2 SSD Replacement: étape 2, image 1 de 3 MSI GT62VR 6RD Dominator M.2 SSD Replacement: étape 2, image 2 de 3 MSI GT62VR 6RD Dominator M.2 SSD Replacement: étape 2, image 3 de 3
    • Insert the plastic opening tool into the seam on the backplate of the laptop.
    • A popping sound will be produced from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator M.2 SSD Replacement: étape 3, image 1 de 2 MSI GT62VR 6RD Dominator M.2 SSD Replacement: étape 3, image 2 de 2
    • Remove the single 1.2mm screw securing the SSD to the laptop using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator M.2 SSD Replacement: étape 4, image 1 de 2 MSI GT62VR 6RD Dominator M.2 SSD Replacement: étape 4, image 2 de 2
    • Remove the old SSD, then insert and screw in the new one.
Matthew Berberich
Membre depuis le 09/18/18
266 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Isn’t that an M.2 Drive not a GPU? the GPU is in the top right. under the heat pipes.
Will Rogers - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 1,270
