Introduction
This guide will help you replace your MSI GT70 MS-1763‘s cooling fan. The fan helps prevent the computer from overheating while it is running. If your computer feels very hot to the touch or if it is turning on but then shutting down quickly, then you most likely need a new fan.
Before beginning the guide, power off your device, remove it from the charging cable and disconnect it from the battery to prevent damage to internal components.
Ce dont vous avez besoin
Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
Remove the back cover.
Remove the single 3 mm screw holding the cooling fan in place with a Phillips #0 screwdriver.
