Aller au contenu principal
MSI GT70 MS-1763 Screen Replacement
Ce dont vous avez besoin
  1. MSI GT70 MS-1763 Screen Replacement, Battery: étape 1, image 1 de 2 MSI GT70 MS-1763 Screen Replacement, Battery: étape 1, image 2 de 2
    • Power off the laptop and turn it over.
  2. MSI GT70 MS-1763 Screen Replacement: étape 2, image 1 de 2 MSI GT70 MS-1763 Screen Replacement: étape 2, image 2 de 2
    • Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
  3. MSI GT70 MS-1763 Screen Replacement: étape 3, image 1 de 2 MSI GT70 MS-1763 Screen Replacement: étape 3, image 2 de 2
    • While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
  4. MSI GT70 MS-1763 Screen Replacement, Screen: étape 4, image 1 de 2 MSI GT70 MS-1763 Screen Replacement, Screen: étape 4, image 2 de 2
    • Remove the rubber guards covering the two 3mm screws on the bottom of the screen. Next, remove the screws with a Phillips #0 screwdriver.
  5. MSI GT70 MS-1763 Screen Replacement: étape 5, image 1 de 2 MSI GT70 MS-1763 Screen Replacement: étape 5, image 2 de 2
    • Using a Jimmy, remove the outside cover around the screen.
  6. MSI GT70 MS-1763 Screen Replacement: étape 6, image 1 de 3 MSI GT70 MS-1763 Screen Replacement: étape 6, image 2 de 3 MSI GT70 MS-1763 Screen Replacement: étape 6, image 3 de 3
    • Remove the six Phillips #0 screws holding the screen in place.
    • Separate screen from the assembly with a Jimmy.
    • Remove the display cable from its connector on the back of the screen.
    • Remove the screen.
Cruz Uribe
Membre depuis le 08/22/19
267 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 21
Total : 1,022
