Aller au contenu principal
MSI GT72 2QE Dominator Pro CD Drive Replacement
Ce dont vous avez besoin
  1. MSI GT72 2QE Dominator Pro CD Drive Replacement, CD Drive: étape 1, image 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement, CD Drive: étape 1, image 2 de 2
    • Remove the indicated seven (7) 6 mm Phillips #0 screws for the back cover.
    • The same PHO screwdriver bit can be used throughout all the steps.
  2. MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 2, image 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 2, image 2 de 2
    • Lift the back cover using the tab to expose the hardware beneath.
  3. MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 3, image 1 de 3 MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 3, image 2 de 3 MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 3, image 3 de 3
    • Remove the indicated 5mm Phillips #0 screw.
    • This is the only screw holding the CD drive in place. Do not lose it.
  4. MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 4, image 1 de 1
    • Using the plastic opening tool, pull out the CD drive.
  5. MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 5, image 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 5, image 2 de 2
    • Remove the indicated 4mm Phillips #0 screw and metal hinge.
  6. MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 6, image 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 6, image 2 de 2
    • Remove the three (3) indicated 2mm Phillips #0 screws.
  7. MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 7, image 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement: étape 7, image 2 de 2
    • Lift metal cover gently, using the tab like indent located where the arrow is pointed.
    • This should expose the inside of the CD drive.
3 autres ont terminé cette réparation.
Ankit Maurya
Membre depuis le 04/18/17
201 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S17-G2, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S17-G2, Banghart Spring 2017
CPSU-BANGHART-S17S17G2
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 22
Total : 1,731
