Introduction
Using the MSI MS-1782, encountering trouble with the speakers, you will use this guide to replace the speakers. It is important to disconnect the battery before replacing the speakers.
Ce dont vous avez besoin
Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
Gently disconnect the cable connecting the M.2 caddy to the motherboard.
Pull the left speaker out, following the wire, unclipping it as you go to the next.
