Aller au contenu principal
MSI MS-1782 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. MSI MS-1782 Wi-Fi Card Replacement, Back Cover: étape 1, image 1 de 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Wi-Fi Card Replacement: étape 2, image 1 de 3 MSI MS-1782 Wi-Fi Card Replacement: étape 2, image 2 de 3 MSI MS-1782 Wi-Fi Card Replacement: étape 2, image 3 de 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 1 de 3 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 2 de 3 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 3 de 3
    • Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
  4. MSI MS-1782 Wi-Fi Card Replacement: étape 4, image 1 de 2 MSI MS-1782 Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
  5. MSI MS-1782 Wi-Fi Card Replacement: étape 5, image 1 de 2 MSI MS-1782 Wi-Fi Card Replacement: étape 5, image 2 de 2
    • Remove the Wi-Fi card at its angle.
To reassemble your device, follow these instructions in reverse order and make sure you put the antenna wires back in the correct order.
A'kia
Membre depuis le 03/08/23
193 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 117
