Aller au contenu principal
MSI PR600 MS-16372 RAM Replacement
Ce dont vous avez besoin
  1. MSI PR600 MS-16372 RAM Replacement, Battery: étape 1, image 1 de 1
    • First, turn off the computer and unplug the power cord.
    • If laptop is not unplugged from the power cord, you could be at risk of electric shock.
  2. MSI PR600 MS-16372 RAM Replacement: étape 2, image 1 de 1
    • Flip laptop over so that you are looking at the bottom of the laptop.
    • Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
  3. MSI PR600 MS-16372 RAM Replacement: étape 3, image 1 de 1
    • Switch the tab labeled "Battery lock" to the unlocked position.
    • Slide the tab labeled "Release" to the right and hold it down.
    • While holding the "Release" tab to the right, slide the battery out with your left hand.
  4. MSI PR600 MS-16372 RAM Replacement, RAM: étape 4, image 1 de 1
    • Unscrew the four 10 mm Phillips head screws circled in red in the picture using the Phillips 00 screwdriver.
  5. MSI PR600 MS-16372 RAM Replacement: étape 5, image 1 de 1
    • Put your pointer finger underneath the tab and lift up to remove the plastic cover.
  6. MSI PR600 MS-16372 RAM Replacement: étape 6, image 1 de 1
    • Slide the RAM off by pulling it away from the fan.
    • Slide RAM back in to serve as a reset.
Lauren Mewes
Membre depuis le 10/21/18
361 Réputation
3 tutoriels rédigés
Équipe
UC Davis, Team S4-G8, Lore Fall 2018 Membre de l'équipe UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 459
