Aller au contenu principal
MSI VR601 WiFi card Replacement
Ce dont vous avez besoin
  1. MSI VR601 WiFi card Replacement, Open the back cover: étape 1, image 1 de 2 MSI VR601 WiFi card Replacement, Open the back cover: étape 1, image 2 de 2
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: étape 2, image 1 de 2 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: étape 2, image 2 de 2
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: étape 3, image 1 de 1
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
Geir Ove Andersen
Membre depuis le 06/06/22
7 815 Réputation
5 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 525 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 17
Total : 242
