Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Mac Pro 2009-2012, utilisez notre manuel de réparation.
  1. Mac Pro Early 2009 Teardown, Mac Pro Early 2009 Teardown: étape 1, image 1 de 1
    • I took the Mac Pro Apart.
  2. Mac Pro Early 2009 Teardown: étape 2, image 1 de 1
    • added the PSU
  3. Mac Pro Early 2009 Teardown: étape 3, image 1 de 1
    • added the backplane board
  4. Mac Pro Early 2009 Teardown: étape 4, image 1 de 1
    • Front Panel Board
  5. Mac Pro Early 2009 Teardown: étape 5, image 1 de 1
    • Here you can see the LEDs of the Mac Pros, and the DIAG_LED bottom
  6. Mac Pro Early 2009 Teardown: étape 6, image 1 de 1
    • The front panel board to backplane board cable
  7. Mac Pro Early 2009 Teardown: étape 7, image 1 de 1
    • another view of the front panel board
  8. Mac Pro Early 2009 Teardown: étape 8, image 1 de 1
    • Another view of the backplane board
  9. Mac Pro Early 2009 Teardown: étape 9, image 1 de 1
    • BackPlane Board and frontPanel Board linked by FrontPanel Board to BackPlane Board cable
  10. Mac Pro Early 2009 Teardown: étape 10, image 1 de 1
    • Bluetooth antenna connected to the card on the Backplane board. One needs to be careful because if not connected the Antenna needs to be attached in order not to short-circuit the backpanel board.
  11. Mac Pro Early 2009 Teardown: étape 11, image 1 de 1
    • A view of the PCI Slots on the Mac Pro Early 2009
  12. Mac Pro Early 2009 Teardown: étape 12, image 1 de 1
    • Optical Drive Cables on BackPlane Board.
  13. Mac Pro Early 2009 Teardown: étape 13, image 1 de 1
    • A view of the power button that needs to be connected on the front panel board.
  14. Mac Pro Early 2009 Teardown: étape 14, image 1 de 1
    • Processor Cage
  15. Mac Pro Early 2009 Teardown: étape 15, image 1 de 1
    • Left Fan in processor cage with speaker.
  16. Mac Pro Early 2009 Teardown: étape 16, image 1 de 1
    • right fan in processor cage. Remember, two clips to take the a fan apart. Top and Bottom.
  17. Mac Pro Early 2009 Teardown: étape 17, image 1 de 1
    • Unit with, PSU, BackPlane Board, Front Panel Board.
  18. Mac Pro Early 2009 Teardown: étape 18, image 1 de 1
    • Small parts that cover the PSU and Super Drive cables.
  19. Mac Pro Early 2009 Teardown: étape 19, image 1 de 1
    • Processor heatsinks 8 Core
  20. Mac Pro Early 2009 Teardown: étape 20, image 1 de 1
    • Processor Heatsink 4 core
  21. Mac Pro Early 2009 Teardown: étape 21, image 1 de 1
    • We can really see the difference between the 8 core and 4 core.
  22. Mac Pro Early 2009 Teardown: étape 22, image 1 de 1
    • Processor Cage & Left and right Speakers.
  23. Mac Pro Early 2009 Teardown: étape 23, image 1 de 1
    • A nice view of processor board 8 core.
  24. Mac Pro Early 2009 Teardown: étape 24, image 1 de 1
    • CPU B of the processor Board.
  25. Mac Pro Early 2009 Teardown: étape 25, image 1 de 1
    • CPU A of Processor Board.
  26. Mac Pro Early 2009 Teardown: étape 26, image 1 de 1
    • Processor & HeatSink
  27. Mac Pro Early 2009 Teardown: étape 27, image 1 de 1
    • RAID Card for Mac Pro Early 2009
  28. Mac Pro Early 2009 Teardown: étape 28, image 1 de 1
    • Graphic Card
  29. Mac Pro Early 2009 Teardown: étape 29, image 1 de 1
    • Fibre Channel Card
  30. Mac Pro Early 2009 Teardown: étape 30, image 1 de 1
    • Finally the machine is rebuilt
zongo
Membre depuis le 11/24/09
453 Réputation
1 tutoriel rédigé
23 commentaires
Hello,
I have Mac Pro 5,1 intel Xeon W3565 at 3.2 GHz Quad-Core.
It is easy to upgrade in W3565 at 3.33 GHz 6-Core ???
Any intel Xeon W3565 fit in my Mac Pro ?
What CPU sockets supported for ?
Thank you,
Stefanos.
StefMacGR - Réponse
It is socket-b(LGA 1366)
I think it is easy to upgrade your CPU
sendercustom - Réponse
It should be easy to upgrade a single-cpu Pro, they use standard lidded Xeons. I am planning on upgrading to W3690s in a couple of 4,1 machines that have had their firmware flashed to 5,1.
tobiasboyd - Réponse
Please let me know how you handle that upgrade!! Or add a tutorial id vey much like to see that and maybe follow suit but im not very savy with these upgrades
Will -
Is it possible to easily remove and service right processor fan (the back one)? It makes too much noise, so needs some oil apparently. I didn't find any way to remove it.
Andriy Tevelyev - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 28
30 derniers jours : 181
Total : 116,046
