Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mac Pro First Generation GTX 660 Installation
Ce dont vous avez besoin
    1. Mac Pro First Generation GTX 660 Installation, Case Panel: étape 1, image 1 de 1
      • Lift the lever to unlock the case.
      Demander à FixBot
      Ajouter un commentaire
    2. Mac Pro First Generation GTX 660 Installation: étape 2, image 1 de 1
      Outil utilisé dans cette étape :
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      Demander à FixBot
    1. Mac Pro First Generation GTX 660 Installation, GPU (Graphics Card): étape 3, image 1 de 1
      • Locate the graphics card in the open panel side of your Mac Pro.
      Demander à FixBot
    2. Mac Pro First Generation GTX 660 Installation: étape 4, image 1 de 3 Mac Pro First Generation GTX 660 Installation: étape 4, image 2 de 3 Mac Pro First Generation GTX 660 Installation: étape 4, image 3 de 3
      • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
      • Remove the slide lock.
      Demander à FixBot
    3. Mac Pro First Generation GTX 660 Installation: étape 5, image 1 de 3 Mac Pro First Generation GTX 660 Installation: étape 5, image 2 de 3 Mac Pro First Generation GTX 660 Installation: étape 5, image 3 de 3
      • Push up on the clip directly behind the graphics card to release it from its slot.
      • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
      • Handle the card only by its edges. Don't touch any exposed components or connectors.
      Demander à FixBot
    1. Mac Pro First Generation GTX 660 Installation, Unplug Your Machine: étape 6, image 1 de 1
      • Unplug your Mac Pro completely (USB Devices, Keyboard and mouse, Monitor, and of course power)
      Demander à FixBot
    2. Mac Pro First Generation GTX 660 Installation, Opening the Mac Pro: étape 7, image 1 de 1
      • Then open your Mac Pro by releasing the latch on the back of the machine, it should look like the picture, if you have trouble releasing this latch, use as much force as possible, it takes strength to work on this machine.
      Demander à FixBot
    3. Mac Pro First Generation GTX 660 Installation, What your machine should look like: étape 8, image 1 de 1
      • Your Mac Pro should look something like this. If not then look for another guide or use this one as a helper for any 2nd gen Mac Pro's but the process is very similar for PowerMac G5 machines (minus the software task) sorry for the stock photo
      Demander à FixBot
    4. Mac Pro First Generation GTX 660 Installation, Removing your Current GPU: étape 9, image 1 de 3 Mac Pro First Generation GTX 660 Installation, Removing your Current GPU: étape 9, image 2 de 3 Mac Pro First Generation GTX 660 Installation, Removing your Current GPU: étape 9, image 3 de 3
      • In order to remove your current GPU, look for the PCI Cover located above the GPU to the back
      • Remove the two Screws holding the GPU in place
      • For Users with current Radeons: Remove the power connector from the board as shown in picture 2, you shouldn't need the PCI Power Adapter that you bought unless your GPU Uses 2 connectors
      • After removing the pci cover and the power connector (Radeon users), go ahead and pull the tab as shown in picture 3 away from your current GPU and lift out your GPU
      Demander à FixBot
    5. Mac Pro First Generation GTX 660 Installation, Inserting Your New GTX 660: étape 10, image 1 de 3 Mac Pro First Generation GTX 660 Installation, Inserting Your New GTX 660: étape 10, image 2 de 3 Mac Pro First Generation GTX 660 Installation, Inserting Your New GTX 660: étape 10, image 3 de 3
      • Get your GTX 660 and insert it into the first PCI slot (the one your last GPU was in)
      • Go ahead and plug in your PCI Power connector into the PCI power outputs on the motherboard
      • Then plug the PCI Power Cable into the GPU, you should only need one if you bought the ASUS one
      Demander à FixBot
    6. Mac Pro First Generation GTX 660 Installation, Powering the machine on after instalation: étape 11, image 1 de 3 Mac Pro First Generation GTX 660 Installation, Powering the machine on after instalation: étape 11, image 2 de 3 Mac Pro First Generation GTX 660 Installation, Powering the machine on after instalation: étape 11, image 3 de 3
      • Plug the machine into power, monitor, keyboard and mouse, leave the machine open just in case.
      • Go ahead and press the power button on the front of the machine
      • You may see a black screen or a "no signal" message on the monitor due to your graphics card being made for PC, give your mac pro max 5 mins to boot.
      Demander à FixBot
    7. Mac Pro First Generation GTX 660 Installation, Installing Graphics Drivers: étape 12, image 1 de 2 Mac Pro First Generation GTX 660 Installation, Installing Graphics Drivers: étape 12, image 2 de 2
      • If everything goes well, you should be able to see your login screen, go ahead and login, if you don;t have graphics acceleration, go ahead and download the nVidia web drivers, you can do it through a usb by using another mac or do it through your Mac Pro, it may just be a pain in the butt to use.
      Demander à FixBot
Your Mac Pro (Running OS X 10.8.5 or above) should be recognizing your new GTX 660, when the PCI Express utility pops up (or open it manually by searching in spotlight "PCI Utility"), make sure to get your GTX 660 to the highest possible speed (8x or 16x), your GTX 660 should be in PCI Slot 1 unless otherwise. If you have an extra card in your PCI Slot(s), try to use the PCI Utility to make both cards run at 8x speeds, but is reccomended to only have the GTX 660 in the PCI bay's so you can run it at the max speed it can go. The example used in this guide is my very own Mac Pro 1,1 (2.66 gHz D Core Xeon's, 12GB DDR2 Ram, (now) GTX 660 By Asus, and a 1TB HDD 5200RPM) Running Mac OS X El Capitan 10.11.6 (Update Pending) this guide should work in any first generation esk Mac Pro (2006-2008) but should also work in 2009-2012 but not sure completely because i dont own one personally.
3 autres ont terminé cette réparation.
Jackson Thiesen
Membre depuis le 12/13/17
235 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
What graphics are compatible
Óscar Da Vila Martín - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 58
Total : 5,020
