Aller au contenu principal
Introduction
Accessing the RAM is easy and requires no tools. Use this guide to add or replace RAM for your Mac Pro.
  1. Lift the lever to unlock the case.
    • Lift the lever to unlock the case.
  2. Remove the side panel of the Mac Pro.
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components.
  3. Locate the two RAM trays at the bottom of the Mac Pro.
    • Locate the two RAM trays at the bottom of the Mac Pro.
  4. Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown. Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
    • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
    • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
  5. Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side. To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place. To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
    • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
    • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
16 autres ont terminé cette réparation.
Andrew Kim
Membre depuis le 12/10/2014
1 101 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-24, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 membres
13 tutoriels rédigés
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 85
Total : 18,141
