Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mac mini (PowerPC) Optical Drive Replacement
Ce dont vous avez besoin
    1. Mac mini (PowerPC) Optical Drive Replacement, Top Housing: étape 1, image 1 de 2 Mac mini (PowerPC) Optical Drive Replacement, Top Housing: étape 1, image 2 de 2
      • Power down your Mac mini, disconnect all of the cables, and flip it over.
      • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
      • The Jimmy should reach a stop about 3/8" down.
      Demander à FixBot
      Ajouter un commentaire
    2. Mac mini (PowerPC) Optical Drive Replacement: étape 2, image 1 de 3 Mac mini (PowerPC) Optical Drive Replacement: étape 2, image 2 de 3 Mac mini (PowerPC) Optical Drive Replacement: étape 2, image 3 de 3
      • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
      • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
      Demander à FixBot
    3. Mac mini (PowerPC) Optical Drive Replacement: étape 3, image 1 de 2 Mac mini (PowerPC) Optical Drive Replacement: étape 3, image 2 de 2
      • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
      • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
      Demander à FixBot
    4. Mac mini (PowerPC) Optical Drive Replacement: étape 4, image 1 de 2 Mac mini (PowerPC) Optical Drive Replacement: étape 4, image 2 de 2
      • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
      Demander à FixBot
    5. Mac mini (PowerPC) Optical Drive Replacement: étape 5, image 1 de 2 Mac mini (PowerPC) Optical Drive Replacement: étape 5, image 2 de 2
      • Keep working around the perimeter, freeing the clips along the final edge.
      Demander à FixBot
    6. Mac mini (PowerPC) Optical Drive Replacement: étape 6, image 1 de 2 Mac mini (PowerPC) Optical Drive Replacement: étape 6, image 2 de 2
      • Flip the Mac mini back over and lift the top housing off of the lower housing.
      Demander à FixBot
    1. Mac mini (PowerPC) Optical Drive Replacement, Mass Storage Unit: étape 7, image 1 de 1
      • If your mini does not have Airport installed, then skip this step.
      • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
      Demander à FixBot
    2. Mac mini (PowerPC) Optical Drive Replacement: étape 8, image 1 de 1
      • Remove the yellow tape securing the power button cable to the black plastic framework.
      Demander à FixBot
    3. Mac mini (PowerPC) Optical Drive Replacement: étape 9, image 1 de 1
      • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
      Demander à FixBot
    4. Mac mini (PowerPC) Optical Drive Replacement: étape 10, image 1 de 1
      • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
      Demander à FixBot
    5. Mac mini (PowerPC) Optical Drive Replacement: étape 11, image 1 de 1
      • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
      • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
      Demander à FixBot
    1. Mac mini (PowerPC) Optical Drive Replacement, Optical Drive: étape 12, image 1 de 1
      • Remove the four silver Phillips screws attaching the optical drive to the black plastic framework (two on each side).
      Demander à FixBot
    2. Mac mini (PowerPC) Optical Drive Replacement: étape 13, image 1 de 1
      • If your mini does not have a Bluetooth board, you may skip the following step.
      • Remove the yellow tape securing the Bluetooth antenna cable to the black plastic framework.
      • Lift the silver Bluetooth antenna board out of its slot.
      Demander à FixBot
    3. Mac mini (PowerPC) Optical Drive Replacement: étape 14, image 1 de 1
      • The cables you're about to remove are very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
      • Flip the mass storage assembly over and disconnect the speaker and fan cables from the interface board.
      Demander à FixBot
    4. Mac mini (PowerPC) Optical Drive Replacement: étape 15, image 1 de 1
      • Flip the mass storage assembly back over. Grasp either side of the plastic framework and push the optical drive away from you with your thumbs on either side of the bezel until you hear it pop free.
      • Lift the optical drive and attached interface board up from the assembly.
      Demander à FixBot
    5. Mac mini (PowerPC) Optical Drive Replacement: étape 16, image 1 de 1
      • Remove the two silver Phillips screws connecting the interface board to the optical drive.
      Demander à FixBot
    6. Mac mini (PowerPC) Optical Drive Replacement: étape 17, image 1 de 1
      • Grasp either side of the interface board and wiggle it free of the optical drive.
      Demander à FixBot
20 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
635 tutoriels rédigés
1 commentaire de tutoriel
If you are careful, there is no need to remove the whole storage unit and can unscrew the optical drive after removing the top case. The screws at the back are a bit tricky, but not impossible to remove while the storage unit remains attached to the logic board and bottom cover.
Miles Raymond - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 67
Total : 24,218
