Introduction
Use this guide to strip and replace the drive tray and IR sensor in your Mac mini Late 2014.
This guide was made with a Fusion Drive Mac mini, and may have more connectors and components than your model. Don't be alarmed if you're missing a hard drive or SSD connector!
Ce dont vous avez besoin
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
Remove the two 12 mm T6 screws from the fan.
Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
Outil utilisé dans cette étape :Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
Outil utilisé dans cette étape :Tweezers$4.99
Use tweezers or your fingers to pull the clip away from the AC-in socket, and remove it from the Mac mini.
Remove the four (two on each side) 6.5 mm T8 screws securing the hard drive to the drive tray.
12 autres ont terminé cette réparation.
