Aller au contenu principal
Mac mini Late 2014 Hard Drive Replacement
Ce dont vous avez besoin
  1. Mac mini Late 2014 Hard Drive Replacement, Bottom Cover: Ă©tape 1, image 1 de 1
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 2, image 1 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 2, image 2 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 2, image 3 de 3
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 3, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 3, image 2 de 2
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 Hard Drive Replacement, Antenna Plate: Ă©tape 4, image 1 de 1
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 5, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 5, image 2 de 2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 6, image 1 de 1
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 7, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 7, image 2 de 2
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 8, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 8, image 2 de 2
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 9, image 1 de 1
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 Hard Drive Replacement, Fan Assembly: Ă©tape 10, image 1 de 1
    • Remove the two 12 mm T6 screws from the fan.
    • Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
  11. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 11, image 1 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 11, image 2 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 11, image 3 de 3
    • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
    • Do not attempt to remove the fan entirely.
    • Lift the fan straight up to free the captive screw from its hole in the logic board.
    • Pull the fan away from the SSD until you can easily access the fan connector.
  12. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 12, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 12, image 2 de 2
    • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
  13. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 13, image 1 de 1
    • Remove the fan from the Mac mini.
  14. Mac mini Late 2014 Hard Drive Replacement, Logic Board Assembly: Ă©tape 14, image 1 de 1
    • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
  15. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 15, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 15, image 2 de 2
    • Remove the SATA cable connector bracket.
  16. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 16, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 16, image 2 de 2
    • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
  17. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 17, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 17, image 2 de 2
    • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
  18. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 18, image 1 de 1
    • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  19. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 19, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 19, image 2 de 2
    • Remove the PCIe SSD cable bracket.
  20. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 20, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 20, image 2 de 2
    • Lift the PCIe SSD connector up off its socket.
  21. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 21, image 1 de 1
    • Remove the single 16 mm T6 screw securing the logic board.
  22. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 22, image 1 de 1
    Outil utilisé dans cette étape :
    Mac mini Logic Board Removal Tool
    J'achète
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
  23. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 23, image 1 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 23, image 2 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 23, image 3 de 3
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the removal tool makes contact with the opening in the rear case.
    • Remove the Mac mini Logic Board Removal tool.
  24. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 24, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 24, image 2 de 2
    • Pull the DC-In cable connector straight out of its socket on the logic board.
  25. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 25, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 25, image 2 de 2
    • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
  26. Mac mini Late 2014 Hard Drive Replacement, Power Supply: Ă©tape 26, image 1 de 3 Mac mini Late 2014 Hard Drive Replacement, Power Supply: Ă©tape 26, image 2 de 3 Mac mini Late 2014 Hard Drive Replacement, Power Supply: Ă©tape 26, image 3 de 3
    • The AC-in socket is secured with a small metal retaining clip.
    • Use tweezers or your fingers to pull the clip away from the AC-in socket, and remove it from the Mac mini.
    • When replacing the clip, push it in until it stops—it should be secure even if there is no audible click.
  27. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 27, image 1 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 27, image 2 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 27, image 3 de 3
    • To free the power supply from the case, grab the AC-In connector, which acts like a latch.
    • Rotate the AC-In connector 90 degrees counter-clockwise.
  28. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 28, image 1 de 1
    • The AC-In latch should fit into the groove above it in the case.
    • During reassembly ensure the power supply is inserted far enough into the case that the latch will engage with the groove.
  29. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 29, image 1 de 1
    • Remove the 8 mm T6 screw securing the power supply.
  30. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 30, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 30, image 2 de 2
    • Slide the power supply out of the mini, minding any cables that may get caught.
  31. Mac mini Late 2014 Hard Drive Replacement, Drive Tray Assembly: Ă©tape 31, image 1 de 1
    • Remove the single 8 mm T6 screw securing the drive tray.
  32. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 32, image 1 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 32, image 2 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 32, image 3 de 3
    • Lift the drive tray up out of the Mac mini.
  33. Mac mini Late 2014 Hard Drive Replacement, Hard Drive Assembly: Ă©tape 33, image 1 de 2 Mac mini Late 2014 Hard Drive Replacement, Hard Drive Assembly: Ă©tape 33, image 2 de 2
    • Remove the four (two on each side) 6.5 mm T8 screws securing the hard drive to the drive tray.
  34. Mac mini Late 2014 Hard Drive Replacement: Ă©tape 34, image 1 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 34, image 2 de 3 Mac mini Late 2014 Hard Drive Replacement: Ă©tape 34, image 3 de 3
    • Lift the hard drive up and remove it from the drive tray.
    • During reassembly, be sure to thread the hard drive cable through the slot in the drive tray.
  35. Mac mini Late 2014 Hard Drive Replacement, Hard Drive: Ă©tape 35, image 1 de 3 Mac mini Late 2014 Hard Drive Replacement, Hard Drive: Ă©tape 35, image 2 de 3 Mac mini Late 2014 Hard Drive Replacement, Hard Drive: Ă©tape 35, image 3 de 3
    • Lift up the ribbon cable and carefully peel away the black tape underneath. It secures the SATA cable connector to the PCB of the hard drive. Failing to remove the tape will almost surely cause the contacts soldered to the flex cable to rip from the connector housing, as the retention force of the contacts in the housing is quite low.
    • Pull the SATA cable connector straight out of the hard drive.
    • Carefully peel off the two black, square-shaped sticky pads (one visible in picture) from the corners of the hard drive, and stick them to your new hard drive in the same locations.
1078 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
465 744 RĂ©putation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 767 tutoriels rĂ©digĂ©s
225 commentaires
Hello, the following hard drive goes on the Mac Mini ??
http://www.sandisk.de/products/ssd/sata/...
schneiderschutzraum - RĂ©ponse
no problem. but if you can get a evo 850 or a pro for the 2014 is better
Carlos De Bernard -
All in all, this was a fairly terrifying process, however this guide was a massive help! Thankyou!!
geeksix - RĂ©ponse
This is exactly the reason I purchased their tools. They offer these guides which have helped me save several of my computers and a couple of my phones over the years. The $70 was a small price to pay for the help and I love the tools.
Nick Maietta -
Ordered kit which arrived very quickly from Germany to UK. Only problem with taking it apart was with the IR sensor was difficult to lift up and I ended up pulling the whole fitting off glued it back on but now have no working IR sensor or front light but everything else works fine. Swapped SLOW HDD for SSD and now my Mac MIni is flying.
Andrew - RĂ©ponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 129
7 derniers jours : 1,166
30 derniers jours : 5,276
Total : 991,204
