Introduction
Use this guide to replace a faulty interconnect board.
Ce dont vous avez besoin
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Outil utilisé dans cette étape :Tweezers$4.99
Disconnect the following connectors from the interconnect board:
Bluetooth cable.
IR board cable.
Fan cable.
4 autres ont terminé cette réparation.
