Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mac mini Model A1283 Speaker Replacement
Ce dont vous avez besoin
    1. Mac mini Model A1283 Speaker Replacement, Top Housing: étape 1, image 1 de 2 Mac mini Model A1283 Speaker Replacement, Top Housing: étape 1, image 2 de 2
      • Power down your Mac mini, disconnect all of the cables, and flip it over.
      • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
      • The Jimmy should reach a stop about 3/8" down.
      Demander à FixBot
      Ajouter un commentaire
    2. Mac mini Model A1283 Speaker Replacement: étape 2, image 1 de 3 Mac mini Model A1283 Speaker Replacement: étape 2, image 2 de 3 Mac mini Model A1283 Speaker Replacement: étape 2, image 3 de 3
      • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
      • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
      Demander à FixBot
    3. Mac mini Model A1283 Speaker Replacement: étape 3, image 1 de 2 Mac mini Model A1283 Speaker Replacement: étape 3, image 2 de 2
      • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
      • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
      Demander à FixBot
    4. Mac mini Model A1283 Speaker Replacement: étape 4, image 1 de 2 Mac mini Model A1283 Speaker Replacement: étape 4, image 2 de 2
      • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
      Demander à FixBot
    5. Mac mini Model A1283 Speaker Replacement: étape 5, image 1 de 2 Mac mini Model A1283 Speaker Replacement: étape 5, image 2 de 2
      • Keep working around the perimeter, freeing the clips along the final edge.
      Demander à FixBot
    6. Mac mini Model A1283 Speaker Replacement: étape 6, image 1 de 2 Mac mini Model A1283 Speaker Replacement: étape 6, image 2 de 2
      • Flip the Mac mini back over and lift the top housing off of the lower housing.
      Demander à FixBot
    1. Mac mini Model A1283 Speaker Replacement, Internal Frame: étape 7, image 1 de 1
      • In the next few steps you will be removing the AirPort and Bluetooth antennas (shown in red) from the internal frame. Be very careful, as breaking the brackets will require replacing the internal frame.
      • We will first remove the AirPort antenna, located in the lower left corner of this picture.
      Demander à FixBot
    2. Mac mini Model A1283 Speaker Replacement: étape 8, image 1 de 2 Mac mini Model A1283 Speaker Replacement: étape 8, image 2 de 2
      • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
      • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
      • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
      Demander à FixBot
    3. Mac mini Model A1283 Speaker Replacement: étape 9, image 1 de 2 Mac mini Model A1283 Speaker Replacement: étape 9, image 2 de 2
      • The two Bluetooth antenna boards simply lift off the internal frame.
      • Grab the Bluetooth antenna nearest the port side of the computer by the edges of the board and pull it straight up off the internal frame.
      • Pull carefully, as it may offer significant resistance and release suddenly.
      Demander à FixBot
    4. Mac mini Model A1283 Speaker Replacement: étape 10, image 1 de 1
      • Remove the antenna board near the front of the mini by pulling it straight up off the internal frame.
      • If necessary, remove the piece of tape securing the antenna leads to the internal frame.
      • Be sure to keep track of the springs under each of the three antenna boards.
      Demander à FixBot
    5. Mac mini Model A1283 Speaker Replacement: étape 11, image 1 de 1
      • Use the flat end of a spudger to pry the audio ribbon cable connector up off the audio board.
      Demander à FixBot
    6. Mac mini Model A1283 Speaker Replacement: étape 12, image 1 de 1
      • Remove the following four screws securing the internal frame to the bottom housing:
      • Three 6.7 mm Phillips #00 screws
      • One 9.5 mm Phillips #00 screw
      • The screw in the lower right corner of this image is recessed deep in the internal frame and longer than the other three screws. A flashlight and a thin screwdriver aid in removal.
      Demander à FixBot
    7. Mac mini Model A1283 Speaker Replacement: étape 13, image 1 de 1
      • Lift the internal frame off the bottom housing, starting at the rear edge, until you feel the concealed edge connector on the motherboard disconnect. Then lift straight off, minding the bluetooth and 802.11 antenna cables.
      • When reassembling, the wifi antenna wire routes to the inside of the vent and then over the top of the vent.
      Demander à FixBot
    1. Mac mini Model A1283 Speaker Replacement, Hard Drive: étape 14, image 1 de 1
      • Remove the two Phillips screws connecting the underside of the hard drive to the internal frame.
      Demander à FixBot
    2. Mac mini Model A1283 Speaker Replacement: étape 15, image 1 de 1
      • Remove the two Phillips screws securing the side of the hard drive to the internal frame.
      Demander à FixBot
    3. Mac mini Model A1283 Speaker Replacement: étape 16, image 1 de 1
      • Use the flat end of a spudger to pry the hard drive thermal sensor board off the adhesive securing it to the side of the hard drive.
      Demander à FixBot
    4. Mac mini Model A1283 Speaker Replacement: étape 17, image 1 de 1
      • Remove the strip of tape holding the thermal sensor cable to the hard drive and remove the thermal sensor from the hard drive.
      • You'll want to transfer this thermal sensor to the same position on your new hard drive.
      Demander à FixBot
    5. Mac mini Model A1283 Speaker Replacement: étape 18, image 1 de 2 Mac mini Model A1283 Speaker Replacement: étape 18, image 2 de 2
      • Slide the hard drive toward the speaker to disconnect it from the interconnect board.
      • Lift the hard drive from the edge opposite the fan and remove it from the internal frame.
      Demander à FixBot
    1. Mac mini Model A1283 Speaker Replacement, Speaker: étape 19, image 1 de 1
      • Disconnect the speaker cable connector from the interconnect board by lifting its connector up off the socket on the board.
      Demander à FixBot
    2. Mac mini Model A1283 Speaker Replacement: étape 20, image 1 de 1
      • Use the tip of a spudger to de-route the speaker cable from the clip on the internal frame.
      Demander à FixBot
    3. Mac mini Model A1283 Speaker Replacement: étape 21, image 1 de 1
      • De-route the speaker cable from within the channel in the internal frame.
      Demander à FixBot
    4. Mac mini Model A1283 Speaker Replacement: étape 22, image 1 de 1
      • Remove the four shouldered Phillips screws securing the speaker assembly to the internal frame.
      Demander à FixBot
    5. Mac mini Model A1283 Speaker Replacement: étape 23, image 1 de 1
      • Lift the speaker out of the internal frame.
      • During reassembly, be sure to thread the speaker cable through the opening in the internal frame before fastening the screws down.
      Demander à FixBot
3 autres ont terminé cette réparation.
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 46
Total : 9,788
