Introduction
Use this guide to replace the battery to restore freedom from your charger to your MacBook Air.
Note: If there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
Ce dont vous avez besoin
Outil utilisé dans cette étape :P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
58 autres ont terminé cette réparation.
15 commentaires
Pretty easy; good instructions. Had to fiddle a bit to get the battery back in with a good connection because the battery cable was stiff.
Battery passed Tech Tool Pro’s check.
La batterie du MacBook Air début 2014 est assez simple à changer, c'est même étonnamment simple compte tenu qu'il s'agisse d'un ordinateur Apple.
Le seul point auquel il faut faire attention et qui n'est pas précisé dans le tutoriel, c'est le rangement du câble de la batterie, il faut le plier correctement comme sur l'ancienne batterie afin d'être en mesure de pouvoir brancher la batterie à l'ordinateur une fois celle-ci revissée. Car le câble de la batterie vendue par iFixit est très rigide.
Is there any difference between Macbook Air 11” Early 2014 and Mid 2013 ??
Different battery type/shape maybe?
