Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Air 11" Early 2014 I/O Board Cable Replacement
Ce dont vous avez besoin
    1. MacBook Air 11" Early 2014 I/O Board Cable Replacement, Lower Case: étape 1, image 1 de 1
      Outil utilisé dans cette étape :
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Demander à FixBot
      Ajouter un commentaire
    2. MacBook Air 11" Early 2014 I/O Board Cable Replacement: étape 2, image 1 de 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Demander à FixBot
    1. MacBook Air 11" Early 2014 I/O Board Cable Replacement, Battery Connector: étape 3, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Cable Replacement, Battery Connector: étape 3, image 2 de 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
      Demander à FixBot
    1. MacBook Air 11" Early 2014 I/O Board Cable Replacement, I/O Board Cable: étape 4, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Cable Replacement, I/O Board Cable: étape 4, image 2 de 2
      • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
      Demander à FixBot
    2. MacBook Air 11" Early 2014 I/O Board Cable Replacement: étape 5, image 1 de 1
      • Lift and remove the I/O board cable.
      Demander à FixBot
2 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
477 943 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
78 256 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 52
Total : 2,741
