Introduction
Use this guide to replace the trackpad, and rejoice in gestures.
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable.
Gently slide the ribbon cable out of the ZIF connector.
Adjust, but do not remove the T5 Trackpad Sensitivity Screw to change the trackpad's depth sensitivity.
7 autre(s) ont terminé cette réparation.
3 commentaires
help me pleaseeeeee
Thanks Sam. I had to make one adjustment in order to get the keyboard ribbon cable back in. Using a Magnifier with a light (thanks Pablo), I held the MBA in a 90 degree position under the Magnifier with a light and I was able to clearly see so that I could slide the ribbon back in to the connector.
ALERT TO ALL OWNERS OF THE MacBook Air 11" Early 2014: if you need to replace your trackpad, make sure you determine in advance whether the data cable that connects your logic board to the trackpad’s ZIF connector has 20 pins or 14 pins. Mine has 20 pins and DOES NOT match the one pictured in the iFixit tutorial. It is my understanding that both of those two different trackpads have the same part number: 923-0429, but they are not interchangeable.
