Introduction
Use this guide to remove the MacBook Air 11" Early 2015 trackpad for adjustment or replacement.
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Be carful with the torque when reassembling, these screws seem able to go a little too far and crack through the plastic of the battery.
To elaborate on Daniel’s comment, particularly the middle 6mm screw seems to have a lot of range and can be over-tightened. I stopped and backed it off a little when it appeared to be deforming the cell to the left.
After replacing the battery (IF108-063-2) I found the trackpad click pressure to be noticeably higher. The plastic frame on the replacement bowed out some just above the logos below the center cells, pressing on the trackpad once the lower case was reattached. I used some gentle heat from a hot air gun (I used about 150º C) to soften the plastic and bend it back down. This reduced the pressure on the trackpad.
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
The instructions that come with the BRTONG replacement battery state the following:
1) Discharge it to 2% (quite specific) and then charge to 100% at the first cycle after purchasing
2) Do not discharge the battery pack to 0% as that will damage the battery pack and shorten its life (this does not specify WHEN not to do it. Only during the first cycle?)
This is very different from the ifixit instructions above , but ifixit could be referring just to the calibration, which could be done AFTER the first cycle, and the manufacturer could be referring just to the first cycle, and not to the calibration. I am not sure what to do. But I guess I will follow the manufacturer instructions during the first (and second, to be safe) cycles, and THEN follow the ifixit instructions for calibration.
Discharging the battery all the way to zero does shorten the battery life slightly, but it’s necessary for a proper calibration. Without calibration, the 2% reading is kind of meaningless, since the system can’t get an accurate % reading until after calibration (that’s the whole point of calibration). I’d follow the iFixit instructions (which are also Apple’s instructions) and ignore whatever that battery vendor sent you. You can find more background on calibration here.
Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable.
Gently slide the ribbon cable out of the ZIF connector.
Adjust, but do not remove the T5 Trackpad Sensitivity Screw to change the trackpad's depth sensitivity.
The Trackpad Sensitivity Screw in this model is a T6 Torx screw
Need a description of why and how much to adjust the sensitivity screw. Do you need to put the screw back to its original position?
I agree with andresaldana - it feels like just about all the T5 Torx screws in this model are actually T6 - a much snugger fit. Is there a more official record of whether these Torx screws are T5 or T6?
With one hand, push the keyboard ribbon cable in slightly to access the ZIF connector beneath it.
Use a spudger to flip up the retaining flap.
Gently slide the cable out of the connector.
Be careful with the retaining piece on the ZIF connector, it released with a bit of a fight but then broke when I tried to close it after reinserting the cable. :(
Mine popped off too but I managed to get it back on. The clip has two very small bumps on the side that goes down the way so look for them when trying to re-attach it.
Mine broke too when re-inserting the cable, had to order a new trackpad because of this. Couldn't get it back in and broke off a small piece of plastic trying to fix the latch. I ordered a new trackpad. I really don't hope this happens with the new trackpad.
Markus -
Note on the two ZIF connections. The smaller connection has it's ZIF lock toward the front of the laptop while the wider ZIF connection faces the KB. I busted the keyboard connections thinking the ZIF was in the opposite direction. Had to replace it with a new trackpad.
I have found that I was able to wiggle the cables out of the ZIFs carefully. idk if this works for all ZIF connections and I'd love to hear anyone who has an opinion on removing ZIF cables. But this makes it much easier to remove and not break the ZIF connections.
I work with a Magnifier with a light. Blowing up the subject so you have it really magnified to a high degree helps enormously. I have removed and reattached many zif cables successfully without a hitch. Act like a surgeon.
Worked fine. Even the keyboard ZIF Cable. Reinserting it was bit tricky.
I had a bit of trouble getting the keyboard cable back in before noticing that it needs to be off the surface of the trackpad to slide in. The whole arrangement is awkward; just be patient and take it slowly.
Remove the six 1.5 mm Phillips #00 screws holding the trackpad in place.
The trackpad sold to me by ifixit did not come with the little hinge plates. I had to remove the six other screws and transfer these to the new trackpad. If this is based on using the part as sold here then the photo needs to be corrected to show the six red circles on the phillips screws that are on the trackpad and not on the Mac itself. These are installed quite tightly and I nearly destroyed two of them (on the body side as indicated in the photo) using the correct tool. The six that screw into the trackpad are much more gently installed. I don't think you are generally supposed to remove the six to the chassis of the MBA. Please update this to correct this - UNLESS THE PART FROM APPLE INCLUDES THESE TWO HINGE PLATES AND SCREWS. In that case, please INDICATE THIS difference in the text of the article. It added work and a bit of stress when the two screws were nearly trashed and I realized the new part did not come with replacements. Not good. However, this was otherwise a very easy project. THANKS!
+1 On this comment. The trackpad replacement kit from iFixit does NOT include the hinge plates. The hinge plates must be removed from the removed from the old trackpad (and the additional six screws holding in place). There is the need to replace 12 screws total in this step AND the removal of the old hinge plates to re-use, and re-install on the new, replacement trackpad assembly. This is a critical miss in this step's directions.
coryss -
If someone could please respond ASAP, i was removing one of these screws from the above picture and it was completely destroyed despite my best efforts. The other 5 came out no problem but i have one screw that is stripped beyond use and i have no clue what do to with it at this point
PH#00 was a size too large in my case. Had to use PH#000 instead.
When you’re putting it back together make sure that you don’t put the flatcable through the cutout and stick it between
6 autre(s) ont terminé cette réparation.
Un commentaire
Hi. After my trackpad “click” started failing (it wouldn’t physically feel like a click when pressed and it wouldn’t respond unless you pushed hard and in certain areas) I went through the whole above replacement process with a trackpad I bought off of Amazon. The new trackpad has a better click on the right hand side but the left hand side is not working still.
Could it be that the new trackpad I got also doesn’t work? The reviews on Amazon indicated that the trackpads from this seller sometimes also failed.
Or is there another problem? I noticed there are two black rubber pads (made of a thin foam) that are between the base of the trackpad and the body of the macbook frame, and that in my computer they are worn/frayed. Could this be the problem?
If anyone has any knowledge about this, or advice about how to go about with this repair and trying different things, I would appreciate your help.
When you say:
Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
Nerdily yours,
Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
larryleveen - Réponse
The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
Michael Welham -
I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
Allen - Réponse
The magnetic mat is
GERARD SZAREK -
Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
Frank O'Carroll - Réponse
A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
Michael Mee - Réponse
Thank you for a really smart tip! I will be using that countless more times!
Lilljedahl -
I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
AMG - Réponse
