Aller au contenu principal
MacBook Air 11" Mid 2011 I/O Board Cable Replacement
Ce dont vous avez besoin
  1. MacBook Air 11" Mid 2011 I/O Board Cable Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    J'achète
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 I/O Board Cable Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2011 I/O Board Cable Replacement, Battery: étape 3, image 1 de 2 MacBook Air 11" Mid 2011 I/O Board Cable Replacement, Battery: étape 3, image 2 de 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2011 I/O Board Cable Replacement, I/O Board Cable: étape 4, image 1 de 2 MacBook Air 11" Mid 2011 I/O Board Cable Replacement, I/O Board Cable: étape 4, image 2 de 2
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 11" Mid 2011 I/O Board Cable Replacement: étape 5, image 1 de 2 MacBook Air 11" Mid 2011 I/O Board Cable Replacement: étape 5, image 2 de 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
3 autres ont terminé cette réparation.
Un commentaire
I had no sound (input/output), no video, no ability to work on battery. I followed the steps and discovered that both the battery and the i/o board where not properly connected. So following this manual fixed it all. Many thanks!
Jean Wallemacq - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 16
Total : 5,061
