Introduction
Rock too hard? Use this guide to replace a blown-out right speaker.
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Use the tip of a spudger to de-route the right speaker cable from the channel cut into the logic board.
Annulation : je n'ai pas terminé ce guide.
13 autre(s) ont terminé cette réparation.
