Aller au contenu principal
MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement, Chin and Display Connector Removal: étape 1, image 1 de 1
    • Slide the plastic chin to the right and off the display.
  2. MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement: étape 2, image 1 de 2 MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement: étape 2, image 2 de 2
    • Remove the three T8 torx screws from the bracket
    • This screw hole pattern is different for older MacBook Airs
  3. MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement, Heat and Remove Bezel: étape 3, image 1 de 3 MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement, Heat and Remove Bezel: étape 3, image 2 de 3 MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement, Heat and Remove Bezel: étape 3, image 3 de 3
    • Remove the gasket that runs along the perimeter of the display. You can use a spudger to pry up the bezel and tweezers to pull it out.
    • Be careful to not tear your gasket
    • Apply Heat to loosen the adhesive, in a pinch you do not necessarily need it; but it always helps with adhesives.
    • Begin Prying from the right corner as pictured.
    • The Webcam and Antennae are under the left side of the bezel.
  4. MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement, Replacement of your Right Hinge: étape 4, image 1 de 2 MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement, Replacement of your Right Hinge: étape 4, image 2 de 2
    • Remove the two PH000 screws holding in the LCD board in
    • To replace the display connection you can open the retaining latch and disconnect the cable.
    • If you're replacing the Webcam/ Wifi Antennae Continue on to the next step.
    • WARNING: There is a ribbon cable attached to the center of the board. be very careful not to damage this
  5. MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement: étape 6, image 1 de 3 MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement: étape 6, image 2 de 3 MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement: étape 6, image 3 de 3
    • If you're just replacing your Webcam skip this step
    • Remove the three T8 Torx screws
    • Remove the PH000 screw
    • Flip the board over and disconnect it.
    • The Wifi / Bluetooth / Webcam cable can now be removed and replaced.
  6. MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement: étape 7, image 1 de 1
    • Disconnect your webcam connection,
    • The webcam is held in by the bezel and a small bit of adhesive on the backside of the webcam
To reassemble your device, follow these instructions in reverse order. I recommend cleaning it with alcohol and using VHB tape for glueing the bezel back on.
2 autres ont terminé cette réparation.
Emmett Normand
Membre depuis le 08/09/17
373 Réputation
2 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
136 membres
15 118 tutoriels rédigés
Un commentaire
Buen paso a paso, pero es de tener en cuenta 2 consideraciones. 1. al momento de la apertura, ¿donde se consigue una cama calefactora tran grande?. 2. al momento del sellado, ¿se debe usar un adesivo especial?
diego Pinzon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 21
30 derniers jours : 104
Total : 1,755
