Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Air 13" Early 2014 Right Speaker Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Early 2014 Right Speaker Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
    Demander à FixBot
    Ajouter un commentaire
  2. MacBook Air 13" Early 2014 Right Speaker Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    Demander à FixBot
  3. MacBook Air 13" Early 2014 Right Speaker Replacement, Battery: étape 3, image 1 de 1
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
    Demander à FixBot
  4. MacBook Air 13" Early 2014 Right Speaker Replacement: étape 4, image 1 de 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
    Demander à FixBot
  5. MacBook Air 13" Early 2014 Right Speaker Replacement: étape 5, image 1 de 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    Demander à FixBot
  6. MacBook Air 13" Early 2014 Right Speaker Replacement, Right Speaker: étape 6, image 1 de 1
    • Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
    • Pry up from beneath the wires.
    Demander à FixBot
  7. MacBook Air 13" Early 2014 Right Speaker Replacement: étape 7, image 1 de 3 MacBook Air 13" Early 2014 Right Speaker Replacement: étape 7, image 2 de 3 MacBook Air 13" Early 2014 Right Speaker Replacement: étape 7, image 3 de 3
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Remove the right speaker from the upper case.
    Demander à FixBot
10 autres ont terminé cette réparation.
Jeff Suovanen
Membre depuis le 08/06/13
453 492 Réputation
259 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
31 359 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 44
Total : 5,419
