Introduction
Utilisez ce tutoriel pour remplacer le SSD.
Avant de commencer, éteignez votre appareil. Fermez l'écran et posez-le à l'envers sur une surface douce.
  • Avant de commencer, éteignez votre appareil. Fermez l'écran et posez-le à l'envers sur une surface douce.
  • Retirez les dix vis suivantes :
    • Deux vis Pentalobe P5 9 mm
    • Huit vis Pentalobe P5 2.6 mm
  • Vous trouverez ici le tournevis spécial dont vous aurez besoin pour enlever les vis Pentalobe.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Réponse
My Wiha P5 screwdriver was too big for these screws, but my P4 worked fine.
BrianM -
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Réponse
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Réponse
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Réponse
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Réponse
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Réponse
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Réponse
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Réponse
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Réponse
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Réponse
P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
William Skinner - Réponse
Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
Dennis Eaton - Réponse
Mettez vos doigts entre l'écran et le boîtier inférieur et tirez vers le haut pour détacher le boîtier inférieur.
  • Mettez vos doigts entre l'écran et le boîtier inférieur et tirez vers le haut pour détacher le boîtier inférieur.
  • Enlevez la partie inférieure et mettez-la de côté.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Réponse
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Réponse
  • Déconnectez la batterie avant de commencer.
  • Saisissez la languette en plastic transparent attachée au connecteur de la batterie et tirez-la vers le bord avant de l'appareil pour déconnecter la batterie de la carte mère;
  • Ne tirez pas vers le haut sur le connecteur pendant que vous le déconnectez.
Ajouter un commentaire
  • Retirez la seule vis Torx T9 de 2,9 mm fixant le SSD à la carte mère.
I'm using a T5 Torx screwdriver to remove the SSD retaining screw but it's simply not working, the screwdriver seems slightly too big and I even tried plyers to grab the ends of the screw and turn it but that didn't budge. Are the screws super tight or something? I can't figure out what I'm doing wrong
smokey9112filmz2 - Réponse
I would also like to know that, i have the same problem tried using a standard T5 Torx and the Pentalobe P5 screwdriver, but the both dont work/fit
facebookvincent -
I opened mine with a T-6.
airshack - Réponse
  • Soulevez délicatement l'extrémité du SSD d'environ 1,2 cm et tirez-le tout droit hors de sa prise sur la carte mère.
    • Ne soulevez pas le SSD de plus de 1,2 cm, cela pourrait endommager le SSD ou sa prise sur la carte mère.
  • Au moment de remonter le SSD, assurez-vous qu'il est correctement installé avant de revisser la vis qui le fixe.
Am I able to upgrade my Macbook Air early 2015 from 128Mb SSD to the SSD Samsung 960 (EVO or Pro) 1TB or 2TB?
If so, do a need special adapters?
Ruben Dominguez - Réponse
Is there an adaptor cable or external housing that allows me to transfer the information on my SSD to my other laptop that has a SATA drive?
Redwood Man - Réponse
There are several available at Other World Computing.
NerdsLimited -
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
60 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Jeff Suovanen
Membre depuis le 06/08/2013
179 344 Réputation
144 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
6 492 tutoriels rédigés
15 commentaires
Fairly straight forward once you get the right screwdrivers. Took me less than 10 minutes.
Jesse Collis - Réponse
Where can I get the SSD replacement? I want to upgrade my storage memory on a MBA 13'' early 2014.
Caro -
I have a Model Name: MacBook Air
Model Identifier: MacBookAir6,2
Processor Name: Intel Core i5
Processor Speed: 1.4 GHz
I can't find any PCIe SSD Harddrives available for upgrading. Has anyone had any luck?
Patrick - Réponse
Very simple and straight forward replacement. First-party SSD replacement can be found on ebay (typically removed from parted-out MacBook Airs). Currently they're aren't any third-party parts available.
rickhendricks - Réponse
Where can i download this SSD upgrade?
Kenan - Réponse
Don't forget to re-attach the battery cable before closing up the underside... not that I did or anything ;-/
phil - Réponse
The Relevant Parts list all has incorrect links. Bait & Switch??
Examples:
"$199.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 256 GB"
Actually supplies: 128GB USED
"$349.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 512 GB"
Actually supplies: 256GB USED
carnthehawks - Réponse
Whoops! Looks like we didn't update the details on those parts when we updated the part itself, sorry about that!
Sam Lionheart -
Hi All,
I found this at OWC.
http://eshop.macsales.com/shop/SSD/OWC/A...
Thanks for the great repair guides iFixit!
darylboman - Réponse
How do I clone the content of my current ssd hard drive that I want to upgrade? Basically I want my macbook air ready for use once I install the new ssd drive.
Adrian James Paul Cabrera - Réponse
First off, you would need an enclosure with cable that would let you connect the new/replacement ssd/flash to your existing Air using a USB port. Then use Clone Carbon Copy and copy the inner drive to the outside drive. 30 minute process, at most. Then follow this well-done guide.
Phil L -
Hello everyone,
I bought my MacBook air in June 2014, the last version if the model. Is it possible to replace the SSD of my Mac? let me know please! Thanks!
Luca Ferraro - Réponse
Hi all.
What is the maximum SSD accepted (and recognized by OSX) for Macbook Air Early 2014 ?
I have 256 GB. Can I go above this ?
ebay_mihai - Réponse
I looked into this and was told that the new SSD drives did not play well with this model. Comment ?
Michael T Kennedy - Réponse
Samsung evo 960 and sintech adapter works perfect. 2014 mba plug and play and time machine backup restore.
yesyes yes yes yes - Réponse
Voir les statistiques:
Dernières 24 heures : 54
7 derniers jours : 380
30 derniers jours : 1,803
Total : 181,117
