Aller au contenu principal
Remplacement de la carte mère du MacBook Air 13" début 2015
Ce dont vous avez besoin
  1. Remplacement de la carte mère du MacBook Air 13" début 2015, Boîtier inférieur: étape 1, image 1 de 1
    • Avant de commencer, éteignez votre MacBook. Fermez l'écran et posez-le à l'envers sur une surface souple.
    • Utilisez un tournevis P5 Pentalobe pour retirer les dix vis qui fixent le boîtier inférieur, dont les dimensions sont les suivantes :
    • Deux vis de 9 mm
    • Huit vis de 2,6 mm
    Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
    allison - Réponse
    Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
    bwgvanderveer - Réponse
    I thought I could replace my 256 Gb SSD with 512? regards
    ola m - Réponse
    Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
    andrew - Réponse
    It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
    Larry Smith - Réponse
    tell a model that was not inferior to the speed of the one in the laptop.
    Thank you
    ilyabuhov - Réponse
    Do i need to order tools separately to replace the battery i just ordered?
    anne uhlir - Réponse
    im looking for a Logic Board for a
    Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
    Any help is appreciated.
    Jamie Comstock - Réponse
    P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
    William Skinner - Réponse
    I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
    eric -
    Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
    Dennis Eaton - Réponse
    My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
    Pennny Beach - Réponse
    The supplied kit and instructions worked perfectly!
    Nikolay Andreev - Réponse
    Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
    joemoog - Réponse
    Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
    Merci pour votre aide.
    chicco33 - Réponse
    oui, vous aurez besoin d’un adaptateur, pour completez le changement.
    Dan -
    The tool kit should include tweezers for re-inserting the battery connector.
    Andre Clement - Réponse
    P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
    michaelquinnell - Réponse
    Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
    Thomas Lewis - Réponse
    To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
    Pentalobe 1.2(mm)
    also
    P4 = 0.8
    P6 = 1.5
    Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
    nijafe -
    I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
    Sean Love - Réponse
    Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
    John Brennand - Réponse
    Just installed on a MacBookAir6,2 (13-inch, Early 2014).
    Was very easy.
    New iFixit battery looks great so far:
    Full Charge Capacity (mAh): 4922 -> 7333
    Jonathan Cross - Réponse
    can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
    hawk_lpc -
    Screw P5 Pentalobe 1.2
    Mario Verlent - Réponse
    Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
    Joel Sebastian - Réponse
    Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
    Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
    Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
    Donald Niamath - Réponse
    Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
    Amir Zaidi - Réponse
    Thank you very much for the guilde. My MBA2011 had reborn !
    Billy Wong - Réponse
    Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
    See great advice: Electrostatic Discharge
    Fletcher Cole - Réponse
    … und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
    ... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
    Blatt - Réponse
    Fot All People ha ing trouble finding their SSD
    DONT PRESS CMD +R + POWER
    instead press
    OPTION+CMD+R +POWER
    I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
    Albert - Réponse
    IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
    This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
    Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
    Good luck. - Eric J.
    ECJohansen - Réponse
    On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
    Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
    Rich Garella - Réponse
    shrhh - Réponse
  2. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 2, image 1 de 1
    • Mettez vos doigts entre l'écran et le boîtier inférieur et tirez vers le haut pour détacher le boîtier inférieur.
    • Enlevez la partie inférieure et mettez-la de côté.
    There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
    Jeannie Crowley - Réponse
    To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
    nijafe -
    When closing this back up make sure that the antenna cable is tucked away neatly
    Gabriel - Réponse
    So this is a legit back cover for MacBook Air?
    ASHANTI SMITH - Réponse
    What about disconnecting the battery?
    Luke - Réponse
    I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
    Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
    Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
    Lance Berc - Réponse
    As noted by others, be a bit careful removing the lower case. There is an oblong black plastic locator very near the center of the lower case. Unless you gently pry the bottom cover pretty much straight up, you will break the ends off of the locater.
    BobY - Réponse
    Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
    Nexus - Réponse
    The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
    The driver for the screws inside the case are named, as "T5".
    Jim Henderson - Réponse
  3. Remplacement de la carte mère du MacBook Air 13" début 2015, Connecteur de batterie: étape 3, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015, Connecteur de batterie: étape 3, image 2 de 2
    • Afin de s'assurer que l'ordinateur est bien hors tension et ne se rallumera pas pendant la procédure, il est recommandé de déconnecter la batterie.
    • Saisissez la languette en plastique transparent attachée au connecteur de la batterie et tirez-la parallèlement à la surface de la carte mère en direction du bord avant de l'appareil.
    • Ne tirez pas vers le haut sur le connecteur pendant que vous le déconnectez, vous risqueriez d'endommager la prise du connecteur.
    after disconnect the battery, press and hold 5*10 seconds the powerbutton on your keyboard to unload the capacitors
    Marcel - Réponse
    how does a person put the battery connector back in?- that is the only thing i’m afraid of touching after putting new fan in.
    a smith - Réponse
    I found it was possible to put the battery connector back in as the last step, however having gone through that and found it to be a little challenging, I would actually recommend attaching the battery connector before screwing back in the bracket. That way you’ll put a lot less stress on the connector cable.
    Kevin Epstein -
    When you are plugging the connector back in, make sure to give it some extra pressure to make sure it is all the way in. It may look like it’s in but needs to be pushed harder!
    Connor Dougherty - Réponse
    After disconnecting the power, you may skip directly to step 18. I don’t know why someone would think it necessary to disconnect all the other stuff. There is no need whatsoever to do so. The more things you disconnect, the more things you risk damaging. Many of the parts in steps 4 through 17 are quite delicate, and easy damaged.
    The screw in step 18 is easily accessed without removing even the rubber gasket. Regarding step 18, only remove the screw. (This screw is rather long, with long threads.)
    It’s helpful to take photographs of this area before removing the screw, so you’ll know what it’s supposed to look like when you put it back together.
    AnnoniMoose - Réponse
    There are only 16 steps in this repair process. I wonder whether you are commenting on a different repair.
    rmccord23 -
    What if your battery doesn’t have that clear tab?
    Carla Tisdale - Réponse
    Yep, exactly the issue that I have
    Martin Adams -
    Where can i buy the battery connector?
    Bernie-Khay Dabu - Réponse
    Macbook air 2015 battery connector where can I purchase?
    Connector socket came off, can I just glue it into place?
    Lisa Mac - Réponse
  4. Remplacement de la carte mère du MacBook Air 13" début 2015, Nappe de la carte E/S: étape 4, image 1 de 1
    • Utilisez l'extrémité plate d'un spudger pour tirer le connecteur de la nappe de la carte E/S hors de sa prise sur la carte E/S.
    When putting this back together, be careful you don’t flip I/O board cable. It will fit, but the computer will not work. You’ll know it’s wrong if it covers the fan.
    Tito Jankowski - Réponse
  5. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 5, image 1 de 1
    • Décollez soigneusement la nappe de la carte E/S de l'adhésif la fixant en haut du ventilateur.
    • Pendant le réassemblage, assurez-vous de repositionner cette nappe dans le bon sens. Elle va rentrer si elle est à l'envers, mais l'ordinateur ne démarrera pas.
    the instructions should really indicate you’re only disconnecting one end of the cable. you disconnect the other end in step 6.
    Tom O'Leary - Réponse
    Bonjour,quand je retire la nappe de la carte E/S , l’éclairage de l’écran s’affiche mais quand je remets la nappe de la carte E/S ,j’ai un écran noir.J’attends votre réponse.Cordialement.
    Halston Halston - Réponse
    I literally did this wrong just like you warned not to! Very easy to do…
    Edward Mills - Réponse
    I watched the video twice and went really slowly through steps and it works!!! It was a little scary but we got through it! Thanks so much!!
    Alexae Visel - Réponse
    20.00000.000$
    Dewi Oasis - Réponse
  6. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 6, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 6, image 2 de 2
    • La prise du connecteur suivant est particulièrement profonde. Faites attention lorsque vous le débranchez.
    • En tirant doucement sur la nappe de la carte E/S vers le haut, près de sa connexion à la carte mère, utilisez l'extrémité plate d'un spudger pour travailler à tour de rôle sur les côtés du connecteur pour le faire "sortir" de sa prise.
    • Retirez la nappe de la carte E/S.
    pour le remontage
    de mon coté tout c’est bien passé, il faut juste bien vérifier la nappe de la carte E/S soit à l’endroit, car sinon l’ordinateur refuse de démarrer ( se référer à la photo du coup )
    matthiasf40 - Réponse
    A client was careless and used a fingernail to pry up the cable in one pull. It pulled the socket right off the logic board.
    w98fxr - Réponse
  7. Remplacement de la carte mère du MacBook Air 13" début 2015, Ventilateur: étape 7, image 1 de 1
    • Utilisez la pointe d'un spudger pour retourner soigneusement le clapet de retenue de la prise ZIF de la nappe du ventilateur.
    • Assurez-vous de travailler sur le clapet de retenue à charnière et non sur la prise même.
    Hi, I messed up the socket, is there a replacement for the socket that holds the fans wire.
    leonzar - Réponse
    macbook air 13" early 2015
    leonzar - Réponse
    The end of that cord slips into the channel whose lid you just flipped up. Don’t forget to re-insert that when reseating the fan and before flipping that retaining flap closed, it’s easy to miss and should have been part of these instructions, ifixit!
    John McClung - Réponse
    Thank you so much! Without your comment, I wouldn’t of realized that the ribbon cable is supposed to go into the socket (I know, dumb mistake now that I think about it). You also made me go back and correctly insert the microphone cable. Cheers!
    Nolan Shaffer - Réponse
    After my repair, my fan is super loud now! Any tips?
    heathergminchen - Réponse
    I didn’t find any need to unplug the fan. All I did was remove the three screws which hold the fan to the case and gently fold the fan out of the way. All you are trying to do is gain enough room to route the camera cable into the little cut-out in the I/O board so it can go below the board along the edge of the fan.
    BobY - Réponse
    I agree, BobY. I too didn't disconnect the fan cable. Those retaining flaps are so tiny it's hard even to see whether or not they are flipped up, so I was happy not to have to deal with it. That meant, however, that I had to be extra careful not to stress the fan cable when removing the fan (or more precisely, just lifting it out of the way rather than removing it completely), but I seem to have succeeded.
    rmccord23 -
    I wish I'd read these comments before unplugging that cable. I can't figure out how to reseat the cable so I can close the retaining flap. It would help if I could see it better, or had a better idea of how it was connected before I unplugged it.
    Darrell Rydell - Réponse
  8. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 8, image 1 de 1
    • Décollez le joint en caoutchouc de l'adhésif sur le dessus du ventilateur.
    Note this is not telling you remove the gasket, just separate it from the fan.
    BobY - Réponse
    When putting the computer together, pay attention to the placement of the gasket. It has a pin on the left side the enters the main board from the bottom. The right side straddles the tip of the heat pipe and there is a photo later on with close-up.
    Yishai Sered - Réponse
    That gasket wasn't stuck on very firmly in the first place, and even less so upon completing the repair. I hope that doesn't create a problem. I would feel more confident if iFixit had included a bit of adhesive along with the new (used) I/O board.
    rmccord23 - Réponse
  9. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 9, image 1 de 1
    • Retirez les trois vis suivantes fixant le ventilateur au boîtier supérieur :
    • Une vis Torx T5 de 5,2 mm
    • Une vis Torx T5 de 3,3 mm
    • Une vis Torx T5 de 4,4 mm à courte tête
    I was unable to remove the 4.4 mm screw with the T5. I needed to use the T4 to get a grip so I didn’t strip the head.
    grahammartin - Réponse
    The 3.3mm Torx is actually a 4.4mm
    georgeantoniades - Réponse
    The 4.4mm and the 3.3mm will seem to strip easily but you just have to press really hard!!!
    cat - Réponse
  10. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 10, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 10, image 2 de 2
    • Soulevez le ventilateur du côté de la carte E/S et retirez-le du boîtier supérieur.
    • Le retrait du ventilateur déconnecte également la nappe du ventilateur. Veillez à ne pas la déchirer.
    I didn’t find any need to remove the fan. I had no trouble routing the camera cable between the fan and the I/O board by just tilting the edge of the fan nearest the I/O board up and out of the way (pretty much what is being shown in the picture above).
    BobY - Réponse
    I agree. I had to put something under the tilted (not removed) fan in order to have room to work, but it went okay.
    rmccord23 -
    I removed it but it was a little tricky getting the ribbon cable back in. I was afraid it would break but it finally seated after a little wiggling.
    Erik Bergeman - Réponse
  11. Remplacement de la carte mère du MacBook Air 13" début 2015, Carte E/S: étape 11, image 1 de 1
    • Déconnectez la carte E/S en retirant son câble d'alimentation de sa prise sur la carte mère.
    • Tirez le câble parallèlement à la surface de la carte mère vers le bord droit de l'Air.
    The connector has a latch (at least mine does) that prevents it from simply sliding out. To release it, I inserted a 5/64 flathead screwdriver to lift the edge of the socket. Then the jack and cable easily slides out.
    Rick Silton - Réponse
    I didn’t find any need to disconnect or remove the I/O board. I had no trouble routing the camera cable between the fan and the I/O board without doing anything to the I/O board.
    BobY - Réponse
  12. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 12, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 12, image 2 de 2
    • Utilisez l'extrémité plate d'un spudger pour tirer le connecteur du câble du haut-parleur gauche vers le haut et hors de sa prise sur la carte E/S.
    • Faites levier en dessous des fils.
    when i did this the whole socket came off the board and i had to get a replacement i/o board. Be warned, do this very carefully and avoid my mistake
    ForceGhostJeremy - Réponse
    I didn’t find any need to do anything to the I/O board/cables. I had no trouble routing the camera cable between the fan and the I/O board without doing anything to the I/O board or any of the cables attached to it.
    BobY - Réponse
    If you are here to replace the logic board, you can skip steps 12-16, they’re unnecessary to replace the logic board.
    maccentric - Réponse
    How do you put this back?? I’m struggling to figure out how to get the connector back into the socket of the new I/O board
    Katie McC - Réponse
    You just line it up and push it down into the socket. Straight down, not sideways.
    maccentric -
    For Display disassembly you can skip this step.
    I replaced a broken display of a MB Air with the functional of another MB Air. I removed the I/O board while disassembling the first Display, then I saw the comments so I tried it out while disassembling the second display. Worked out totally fine and saved me some time.
    Luis - Réponse
  13. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 13, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 13, image 2 de 2
    • Utilisez la pointe d'un spudger pour retourner soigneusement le clapet de retenue de la prise ZIF de la nappe du microphone.
    • Assurez-vous de faire levier sur le clapet de retenue et non sur la prise même.
    There was black tape covering this socket. It was attached to the ribbon tape. I needed to pull up the tape covering the socket to expose the retaining clip.
    Brant Smith - Réponse
    The note about the black tape should be in RED in the main text above. I broke off the connector thinking the tape was part of the cable assembly. Always read the comments. Always. : )
    Jon Lucenius - Réponse
    As I mentioned in previous steps, I didn’t find a need to do any of this.
    BobY - Réponse
    Ripped the connector off the picture was too small and I couldn’t see what part to lift.
    Mo Ali - Réponse
    If you click on the picture, you'll get a nice detailed blown-up view.
    maccentric -
  14. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 14, image 1 de 1
    • Retirez la seule vis Torx T5 de 4,1 mm fixant la carte E/S au boîtier supérieur.
    Steps 14-15 & 28-29 seem unnecessary. I managed to replace the logic board without removing the I/O board or right speaker, although that means the logic board cannot be removed easily - the right rear corner is hindered by part of the chassis so that the edge of the logic board facing the battery should be lifted gently first and then the board be slid away from that obstructing part.
    Wai Wong - Réponse
    BobY - Réponse
    Steps and their numbering may have changed in the meantime.
    For pure display disassembly/reassembly you can skip Steps 13-14 and Step 16, i.e. no need to remove the I/O board.
    Luis - Réponse
  15. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 15, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 15, image 2 de 2
    • Dégagez délicatement le câble de la caméra de son entaille sur la carte E/S et poussez-la de côté avec la pointe d'un spudger.
    This is really tricky. I couldn't de-route the cable as long as the I/O board was still in place. Had to lift the board mostly out of place in order to get enough slack in the cable to de-route it. Otherwise, I was going to have to force the de-routing, which seemed like a really bad idea.
    rmccord23 - Réponse
  16. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 16, image 1 de 1
    • Soulevez la carte E/S du côté de la carte mère et retirez-la du boîtier supérieur.
    • Le retrait de la carte E/S déconnecte également la nappe du microphone. Veillez à ne pas la déchirer.
    The I/O board does not need to be removed to remove the display.
    Macman - Réponse
    Nor for the logic board removal
    The back end of the microphone riibbon cable may be stuck down with a bit of glue under the flap. You can gently loosen it with a flat spudger.
    Richard Garella - Réponse
    how do I reattach the riibbon cable now that the adhesive has been removed?
    Nolan Shaffer -
    As I mentioned in previous steps, I didn’t find any need to do this.
    BobY - Réponse
    I wonder if you weren't replacing the I/O board, BobY, but rather were doing some other repair. I say this because the microphone ribbon cable has to be disconnected from the I/O board in order to replace the I/O board, which is the repair that I was working on. And that disconnect/reconnect was definitely the fussiest part of this entire repair. Such tiny components to handle! In the end, I had to resort to using a tweezers, and even then I wasn't sure that everything was fully seated and secure.
    rmccord23 -
    I wasn't replacing the I/O Board, I was replacing the entire Display Assembly--I got to this step within the instructions for replacing the Display Assembly. Maybe iFixit uses the same comments if they link to this same step from a different set of repair instructions? My comment was meant to convey you definitely don't need to remove the I/O Board to replace the Display Assembly.
    BobY -
    I got to this point (Step 16) within the instructions for replacing the Display Assembly, which is where I'm entering this comment. My comment was meant to convey it isn't necessary to remove the I/O Board to replace the Display Assembly, but you certainly would need to remove the I/O Board to replace the I/O Board.
    BobY - Réponse
  17. Remplacement de la carte mère du MacBook Air 13" début 2015, Batterie: étape 17, image 1 de 1
    • Dévissez les cinq vis suivantes fixant la batterie au boîtier supérieur :
    • Trois vis Torx T5 de 6,9 mm
    • Deux vis Torx T5 de 3,0 mm
    what is that little hole or clip in the middle o battery?
    Edy Surpat - Réponse
    There’s both a hole for a screw and a clip to hold the bottom case
    maccentric -
    Hello,
    the battery is now delivered with a transparent plastic taped allover the new battery.
    is it needed or shall it be removed
    kind regards
    Maes Michel - Réponse
    Hello,
    If the plastic is easily removable from the battery, it should be removed. However, if the plastic is glued onto the battery, do not remove the plastic.
    Arthur Shi -
    The centre screw (of the three 6.9mm T5 described above) seems to be a bit thicker diameter than the other two corner (6.9mm screws - although I don't have a tool to make precise measurement). Replace this thicker screw to its centre position on the battery.
    Beren Robinson - Réponse
  18. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 18, image 1 de 1
    • En manipulant la batterie, évitez d'appuyer ou de toucher les 4 cellules lithium-polymère apparentes.
    • Soulevez la batterie par le bord le plus près de la carte mère et retirez-la du boîtier supérieur.
    • Votre batterie de remplacement peut arriver avec un film plastique adhérant légèrement à la surface supérieure. Retirez ce film lorsque vous installez la batterie. Cependant, si le film est collé et difficile à retirer, vous devriez le laisser en place.
    • Si vous installez une nouvelle batterie, on vous recommande de la calibrer avant de l'utiliser :
    • Chargez à 100% et pendant au moins deux heures supplémentaires. Puis, débranchez et utilisez votre ordinateur normalement. Lorsque vous voyez le signal de pile faible, enregistrez votre travail et gardez votre ordinateur allumé jusqu'à ce qu'il s'éteigne. Attendez au moins 5 heures puis chargez-le à nouveau jusqu'à 100 % sans interruption.
    • Si vous remarquez un comportement inhabituel ou des problèmes après l'installation de votre nouvelle batterie, vous devrez peut-être réinitialiser le SMC de votre MacBook.
    Personally I would like a short description on why we have to calibrate a brand new battery for what reason?
    Albert - Réponse
    @albertnumber1 You can find a detailed explanation of calibration here. The short(ish) answer is that the battery charge % reading on your device is really just a guess, one that is generated by a mathematical model of what’s going on inside the chemical battery. That model needs data points (like full charge and discharge flags) in order to work correctly. Without calibration, nothing bad will happen, but you may get some unreliable battery % readings.
    Jeff Suovanen -
    1. Glad someone was able to clear up the reason we need to calibrate
    2. During the process, if for some reason, say my cat waltzing all over my desk, disconnects the magsafe for a moment while in the final full charge cycle, what impact would this have?
    Josh Fiddler - Réponse
    The replacement battery’s connector didn’t align with the port as easily as the original’s. Instead of pointing straight back from the battery, the cable pointed at a significant angle. In order to connect the new battery, I had to hold it a slight diagonal angle while connecting it, before placing the new battery into the chassis and securing it.
    After replacing the battery, the laptop (MBA early 2015) shut off immediately whenever it was unplugged from the MagSafe connector, despite reporting a full charge. To resolve this, I performed an SMC reset: I re-opened the case, unplugged the battery, held down the power button for 5 seconds with the battery unplugged, then re-connected the battery, re-attached the lid, and pressed the power button again. It immediately booted up as expected on battery power.
    Garrett Guillotte - Réponse
    I found these two little broken tabs under the battery. Not sure where they came from, but Ididn’t put them back in anywhere.
    https://1drv.ms/u/s!As3YRQaTlkClgcgS6Hhl...
    Norm Hils - Réponse
    These are from the old battery. Not totally necessary.
    Scott Baker -
    Good opportunity to blow or brush away some accumulated dust from a unit like mine (5 -6 years service) when the battery is out. Also at this time, used the thin probe tool to ream out some debris from the rim of the base.
    The replacement battery cable seemed too long to fit well but when I examined the original, I noted a distinct v kink downwards in that one. A gentle push down in the middle formed a V and permitted the new cable to fit Presumably without harm..
    howardmat3 - Réponse
    The instructions on this step say to remove the plastic film on the replacement battery, but the introduction says to leave it on. Which step is correct?
    William Davis - Réponse
    Hi William!
    Good question! If the film is lightly adhered, you can peel and remove the film.
    Arthur Shi -
    Hi how can I discharge the battery (MacBook air 2017) quickly as the battery has swollen and I need to get it out, at the moment I am running lots of apps but it still shows 6%?
    John MacMahon - Réponse
    max screen brightness and run some cpu benchmark
    Daniele Carminati -
    Shorting the battery is very dangerous. Leave the computer on until it shuts down on its own.
    Manuel Jesús Flores Jiménez - Réponse
    The fix kit for this battery comes with a spudger. What is it for?
    mobya45 - Réponse
    Good morning, I just replaced my first battery. The light on the magnet is red now. Will that color change to green to inform me that it is fully charged? Thanks, Julie
    juliecongleton - Réponse
    Re: leaving it unplugged for 5 hours after the battery goes flat - isn't that a bad thing? I thought Li-ion batteries get damaged by letting them go completely flat?
    Cool_Breeze - Réponse
    I have the same question, but from what i read the battery is still on 10% when the mac shuts down (to keep the battery healthy, so the 0% on the mac display is actually not the real battery charge)
    Robert Borck -
    Does anyone know what the four white (or red) dots on the underside of the battery mean?
    Jeffrey Utz - Réponse
    I've got a problem with the second MBA 2017 I did a battery replacement on. Replaced the battery, charged to 100%. Drained the battery and waited 5+ hours. Now it's stuck on 1% and won't charge. I've tried SMC reset by opening it up again, disconnect the new battery, hold the power button for 5 sec, connect the battery again but without any luck. Any suggestions?
    Gustav Svedung - Réponse
    Seems like a power cycle fixed the issue (turning the computer off, unplugging the MagSafe, holding the power button for 10 sec, plugging MagSafe back in).
    Gustav Svedung -
    Installing and conditioning the new battery was a breeze with your instructions and tool. But I get a message saying the date/time was set incorrectly. I could not reset it using the date/time in system preferences and the laptop was running hot with the fan running at full blast. Instead I had to shut it down and restart it in safe mode by pushing the shift button when I heard the start up chime and releasing it when the Apple logo appeared. Once in safe mode the date/time was correct and I restarted in normal mode. It's all good now. iFixit's comments allude to chip dependent issues and your should look at their detailed comments if you are having issues on restart after install. Thanks for a great product!
    Jonathan Kott - Réponse
  19. Remplacement de la carte mère du MacBook Air 13" début 2015, Ensemble carte mère: étape 19, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015, Ensemble carte mère: étape 19, image 2 de 2
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et faites-la pivoter vers le haut de l'ordinateur.
  20. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 20, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 20, image 2 de 2
    • Tirez le connecteur du câble de données de l'écran tout droit hors de sa prise.
    • Assurez-vous de tirer le connecteur parallèlement à la surface de la carte mère, ne le soulevez pas tout droit hors de sa prise.
  21. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 21, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 21, image 2 de 2
    • Utilisez l'extrémité plate d'un spudger pour retirer les deux connecteurs de câble d'antenne de leur prise sur la carte AirPort/Bluetooth.
    One of my terminals is broken. What solutions do you recommend me
    Omar Lopez - Réponse
    You’re actually pushing the connector from side to side toward the front of the case (or towards the track pad). It’s not a vertical motion at all.
    Jay Quilty - Réponse
    I’d also mention to be careful taking these off and putting them back on. I also accidentally pulled a terminal off it’a cable.
    Jean-Pierre Bazinet - Réponse
    If the process is taken to replace the top case, you can leave the AirPort card hanging from the antenna wires. Only remove the card’s retaining screw and slide the card to the right (direction of the antenna connectors) to separate it from the main board.
  22. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 22, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 22, image 2 de 2
    • Débranchez le connecteur du câble de la caméra avec la pointe d'un spudger.
    • Poussez d'abord sur un côté du connecteur, puis de l'autre, pour le "guider" délicatement hors de sa prise.
    • Tirez le câble de la caméra parallèlement à la surface de la carte E/S vers le bord avant de l'Air pour le sortir de sa prise.
    • Ne le soulevez pas ce câble lorsque vous le débranchez, car sa prise risque de se détacher de la carte mère.
    You’ve missed a whole section here on removing the fan. It’s still present in Step 19 pics, but gone by Step 23. It’s not that it’s difficult to work out how to do it. But, when reassembling and following the steps in reverse, it’s handy to know when to use which screws!
    Stuzzington Botulism - Réponse
    Ah! –my bad. The steps for removing Fan etc. are there –up round Step 13. It’s just your photos that are slightly out of sync, as it’s back in place again by Step 19. So, while working in reverse, it looks like it’s not been covered.
    On getting it on — i feel it's implied by the word "push” you can walk it out with the spudger. I couldn't wanage that, and instead walked it out by taking the cord between my index and thumb and walking it out by pulling it to the right and then the left repeatedly in a
    Elijah Kennedy - Réponse
  23. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 23, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 23, image 2 de 2
    • Utilisez la pointe d'un spudger ou votre ongle pour retourner le clapet de retenue de la prise ZIF de la nappe du trackpad.
    • Assurez-vous de faire levier sur le clapet de retenue à charnière et non sur la prise même.
    • Tirez la nappe du trackpad tout droit hors de sa prise vers le bord avant de l'Air.
  24. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 24, image 1 de 3 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 24, image 2 de 3 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 24, image 3 de 3
    • Utilisez la pointe d'un spudger pour faire basculer le clapet de retenue de la prise ZIF nappe du rétro-éclairage du clavier.
    • Utilisez votre spudger pour retirer délicatement la nappe du rétro-éclairage du clavier hors de sa prise.
    Do you know where i can buy the retaining clip ?
    Jo (MemePasGame) - Réponse
    Not sure you can. I’d just use some kapton tape to hold it in place and call it good.
    maccentric -
  25. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 25, image 1 de 1
    • Utilisez l'extrémité plate d'un spudger pour faire levier sur le connecteur du haut-parleur droit et le retirer de sa prise sur la carte mère.
    • Il est recommandé de faire levier en dessous des câbles.
    What is this cables for?
    great.ryankim - Réponse
    It’s a speaker cable
    maccentric -
    This is the one that gave me the hardest time!!! It does pop up and out tho.
  26. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 26, image 1 de 1
    • Retirez les six vis Torx T5 de 6,3 mm fixant la carte mère au boîtier supérieur.
    • Sur certains modèles, il peut s'agir de vis Torx T5 de 4,1 mm.
    When re-assembling the motherboard, attach all 6 screws but do not completely tighten yet.
    First make sure the rubber gasket is sitting properly, that the 7th screw hole (from Step 18) is properly aligned, and the Airport wire is sitting properly and also not caught under the heat sink.
    Once everything is well aligned, start tightening the screws while watching out for the alignment. I found it useful to keep an eye on screw-hole from Step 18 as a reference.
    Rany - Réponse
    Going in this order, there is a 7th screw securing the logic board to the frame; the heatsink is secured to the logic board with 4 screws, and secured to the frame with 1 more screw. Either take the heatsink off first, or remove that last screw underneath two small black wires, next to the left (as viewed when using the computer; if the computer is flipped over with the cover off and the monitor hinge end of the computer farthest from you, it is in the far right corner) set of three big torx screws that hold the hinge in place. The exact location of this screw is pictured in step 35's second picture; the screw goes through the loop visible below the rubber fan insulator. Scoot those 2 li'l wires out of the way and remove that screw, then the logic board comes right out. If this isn't clear, please let me know and I'll try to describe it better, or add a photo. If I'm posting this to the wrong instruction page, let me know; I was pretty sure I correctly identified my rig, but if not, sorry for the N00bage.
    Fox MacLeod - Réponse
    I got an extra screw hiding under the rubber gasket holding the end of the heatsink to the chassis. Ended up bending the heatsink a little cause I wasn't looking for it.
    Corvallis Computer - Réponse
    In the model I was working on, the 6th screw (in the middle) was hiding under the Samsung RAM module. Simply remove the one T5 screw holding it in, slide the RAM module out, and the 6th screw will be exposed.
    Tim - Réponse
    “Samsung RAM module”… do you mean the SSD? That stick of NVRAM is totally your hard drive.
    FeRD - Réponse
    Exactly, he means SSD (storage) the RAM (memory) is soldered to this 820-00165 logic board. Also on this model the 2015 MBA there is no logic board retaining screw under the SSD
    Peter Newman -
  27. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 27, image 1 de 1
    • Retirez les deux vis Torx intérieures de 4,9 mm fixant le dispositif de retenue du câble de l'antenne et la charnière gauche au boîtier.
    This is the same screws as step 17.
    Joseph Lee - Réponse
    In both the online and the PDF version, Steps 17-18 and Steps 29-30 are identical. At which stage should you actually remove the display screws?
    adlerpe - Réponse
    Good catch! We did some sleuthing and it looks like a couple guides did indeed have an extra section of steps! All better now =)
    Sam Goldheart - Réponse
    In my computer these screws were the same size as the other side’s hinge screws. All 6 are the same size.
  28. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 28, image 1 de 1
    • Éloignez légèrement le dispositif de retenue du câble de l'antenne et retirez la vis Torx T5 de 3 mm fixant l'extrémité du dissipateur thermique au boîtier supérieur.
    This step is not needed
    mayer - Réponse
    It’s not clear what you mean by “This step is not needed.” If you want to remove the logic board from the upper case in order to put it onto your replacement upper case, you will have to remove this screw.
    This step is only needed if you’re replacing the ENTIRE top case. Simply swapping out the trackpad unit does not make this step necessary. This entire tutorial assumes you’re replacing the entire top case which is an expensive mistake if you’re simply replacing the trackpad and/or keyboard. The keyboard is removable as well despite those many tiny rivets. Save money and time by not replacing the entire top case for a bad trackpad and/or keyboard. I needed to accomplish this step because I also removed and replaced the keyboard.
    airshack - Réponse
    NOTE: There is a sort of clamp/washer attached to this screw that I didn’t know about until I flipped the laptop up on its side and it fell onto the desk. Also: you need to reset it *before* the motherboard
    In my computer this screw was not there, nor was a related washer. I got it used so perhaps someone has already been there and did not replace the screw.
    Also, the photo here shows how this end of the fan gasket is placed
  29. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 29, image 1 de 3 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 29, image 2 de 3 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 29, image 3 de 3
    • Faites glisser l'extrémité plate d'un spudger sous le haut-parleur droit à partir de l'extrémité la plus proche de la charnière vers le bord avant de l'Air pour décoller l'adhésif.
    • Retirez le haut-parleur droit du boîtier supérieur.
    You don’t really *have* to remove the speaker, especially if your replacement upper case assembly already includes the speakers.
    Alexander Zub - Réponse
    I found the same. If you already have speakers in your new upper case, you can leave them. When you put the logic board back in, it will be a tight fit. I had to start with the corner near the right hinge (the Thunderbolt port corner) and work it in to place.
    If your keyboard and/or trackpad need replacing you do not have to replace the entire top case.
    airshack - Réponse
    If it is difficult to remove the speakers you can use Isopropyl Alcohol to loosen the adhesive holding the speakers in place. Make sure to keep the Isopropyl Alcohol away from the speaker itself.
    BluRepairs - Réponse
  30. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 30, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 30, image 2 de 2
    • Retirez avec précaution l'ensemble carte mère du boîtier, en tenant compte des câbles pouvant rester accrochés.
    • Lors du remontage:
    • Gardez les câbles détachés à l'écart de la carte afin qu'ils ne soient pas coincés en dessous.
    • Assurez-vous que les câbles d'antenne sont insérés dans leur encoche respective sur la carte mère, comme indiqué sur la seconde image.
    It’s probably worth mentioning here that during reassembly you want to tuck the rubber gasket under the extension of the heat sink that the fan slots into.
    David Bonner - Réponse
  31. Remplacement de la carte mère du MacBook Air 13" début 2015, Carte mère: étape 31, image 1 de 1
    • Retirez la seule vis Torx T5 de 2,85 mm fixant le SSD sur la carte mère.
  32. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 32, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 32, image 2 de 2
    • Pour éviter d'endommager sa prise, ne soulevez pas trop la l'extrémité du SSD.
    • Tirez le disque tour droit hors de sa prise et enlevez-le de la carte mère.
    • Lors de la réinstallation du SSD, assurez-vous qu'il est bien en place avant de réinstaller sa vis de retenue.
  33. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 33, image 1 de 1
    • Retirez la seule vis Torx T9 de 2,9 mm fixant la carte AirPort/Bluetooth sur la carte mère.
  34. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 34, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 34, image 2 de 2
    • Pour éviter d'endommager sa prise, ne soulevez pas trop l'extrémité de la carte AirPort/Bluetooth.
    • Soulevez légèrement l'extrémité libre de la carte AirPort/Bluetooth et retirez-la de sa prise sur la carte mère.
    • Retirez la carte AirPort/Bluetooth de la carte mère.
  35. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 35, image 1 de 1
    • Retirez les quatre vis Torx T5 de 2,5 mm fixant le dissipateur thermique sur la carte mère.
  36. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 36, image 1 de 2 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 36, image 2 de 2
    • Si le dissipateur thermique semble rester collé à la carte mère après avoir retiré les quatre vis, utilisez un spudger pour séparer soigneusement le dissipateur thermique de la surface du CPU et du GPU.
    • Retirez le dissipateur thermique de la carte mère.
    • Lors de la réinstallation du dissipateur thermique, assurez-vous d'appliquer une nouvelle couche de pâte thermique. Si vous n'avez jamais manipulé de pâte thermique avant, nous avons un tutoriel qui vous aidera.
  37. Remplacement de la carte mère du MacBook Air 13" début 2015: étape 37, image 1 de 3 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 37, image 2 de 3 Remplacement de la carte mère du MacBook Air 13" début 2015: étape 37, image 3 de 3
    • Lors du remontage de votre appareil, assurez-vous que le joint en caoutchouc du dissipateur thermique est installé correctement. Le petit pic sur le joint devrait correspondre au trou dans la carte mère près des ailettes du dissipateur thermique.
    • La pic du joint devrait rentrer dans l'encoche du dissipateur thermique, il ne devrait pas finir sous l'onglet du dissipateur thermique qui se trouve sur la carte mère.
    • Assurez-vous que les câbles d'antenne sont insérés dans leur encoche respective sur la carte mère, comme indiqué dans la dernière image.
    This step is REALLY helpful. I skimmed over it when disassembling and then struggled a bit trying to get the rubber gasket aligned just right.
    The middle photo shows what I mean, it's exactly what I needed.
    Daniel Cassel - Réponse
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
Déposez vos déchets électroniques dans un point de recyclage certifié.
La réparation ne s'est pas déroulée comme prévu ? Essayez un diagnostic de base, ou demandez de l'aide à notre Forum.
78 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Sam Goldheart
Membre depuis le 10/18/12
465 738 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 767 tutoriels rédigés
15 commentaires
Wow, you saved me $1000 bucks! I spilled brandy on my MacBook Air and followed your instructions to completely strip it down. I followed instructions for cleaning circuit boards after a spill from another page on this site. My MacBook works perfectly now!
Your instructions were great. You might note that there is some variation in the placement of different components, ribbon connectors, etc., but I figured it out by zooming in on your pictures and finding a picture of each exact component. They look the same, even though they are in different spots. I found out you can dunk the circuit boards in 91% rubbing alcohol, clean the parts with a soft toothbrush, and let it all dry. I didn’t bother with removing and replacing the heat sink and thermal paste. After soaking in the alcohol, I saw that the heat sinks were still firmly attached thermal paste looked fine, so I left it alone. I liked your specific descriptions about which way to pull or lift the ribbon connectors, and using the right tools! Thanks!
Sharon - Réponse
I am afraid if you soaked the whole unit in alcohol, the heat sink paste is probably ruined? If the unit seems to get hot or shut off spontaneously, I would consider taking it apart AGAIN, and cleaning and relating the heat sink with fresh new thermal paste. You can clean the old paste off with Alcohol, do you see why that worries me ;~)
max damage -
Do you know where can i buy pre owned motherboard like this that can be trusted? Mine is missused and cant turn on.
triesniaf - Réponse
Can anyone please let me know where to buy Motherboard, my macbook air is not getting started. they said there is a moisture on the logic board.
శ్రీ - Réponse
Hi Sriram, we have links to the motherboards (Apple calls them Logic Boards) at the top of this guide.
Sam Goldheart -
How do you determine which logic board to buy? There are two options. I’d rather not have to disassemble to find out then have to wait for delivery to put back together. Is there somewhere on a Mac site I can plug in the serial number to find out?
Colin - Réponse
If your computer is working you can look in the “About This Mac” menu to learn which processor you have, that will determine which logic board you need. Otherwise check out our “Identify your Mac” tool.
Sam Goldheart -
Replaced the logic board but only the low battery symbol came up on the screen. Water got into the computer and it sat for a while.
Kathleen Valentine - Réponse
This guide was heaven-sent! Saved my family a LOT of money. My pre-owned MBA was purchased via a third party, so when I was hit with ransomware that locked my device with a firmware lock Apple wasn’t able to help me (without proof of purchase). Replacing the logic board, while expensive, was a lot cheaper than scrapping the device and buying a brand new one.
Note to all: If you’re going to buy a Mac from a non-Apple store or official reseller, ALWAYS ask for the original proof of purchase.
Jason Sanders - Réponse
Can I leave the microphone and camera cables disconnected and still use all other functions (MacBook Air early 2015) that don’t rely on either?
Paul - Réponse
How do you re-apply adhesive for when you put the right speaker back on? What adhesive should one use? Do you really need to remove the right speaker in order to take the board out? (Of course the cable needs to be disconnected.)
Michael Fleischmann - Réponse
For me, the thermal paste wasn’t necessary because my new logic board had the heat sink attached but very good guide!
mak467 - Réponse
I was able to replace an i5 logic board with an i7 logic board on an old Macbook Air and it works perfectly thanks to this guide.
James Knox - Réponse
Lucky one as you found a logicboard free from issue. Sometimes surplus/used logicboard ha a "locked" concerns.
Aurora -
Is the M1 logicboard compatible to Air 2015 Macbook Air logicboard?
Aurora - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 21
7 derniers jours : 137
30 derniers jours : 671
Total : 125,878
