Introduction
Use this guide to replace your Air's I/O board which houses the MagSafe DC-in port, a USB socket, and the headphone jack.
Ce dont vous avez besoin
Vidéo d'introduction
Outil utilisé dans cette étape :P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 9 mm 5-point Pentalobe screws
Eight 2.6 mm 5-point Pentalobe screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
Carefully peel the I/O board cable from the top of the fan.
While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
Remove the I/O board cable.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
22 autres ont terminé cette réparation.
3 commentaires de tutoriel
Superb instructions - made it easy!
Thanks! It saved me $250 dollars doing this. One thing I want to mention to anyone doing this, be careful with the dis-attachment of some smaller cables. They are very sensitive and have tiny parts sometimes that can come off. Fortunately for me, it didn’t prevent it from working, but just a warning. Notice how you are detaching those little cables very carefully before putting them back. I’m thinking about the microphone cable connector up and out of its socket on the I/O boar specifically.
