Aller au contenu principal
Introduction
Use this guide to replace a faulty trackpad in a Late 2020 MacBook Air (M1).
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  1. Wedge your fingers between the display and the lower case and pull upward to pop off the lower case. Remove the lower case. To reinstall the lower case:
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  2. Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector. Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch. Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
  3. Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  4. Remove the trackpad cable cover.
    • Remove the trackpad cable cover.
  5. Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket. Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  6. Carefully peel the trackpad cable off of the battery.
    • Carefully peel the trackpad cable off of the battery.
    • The trackpad cable is secured to the battery with some light adhesive.
  7. Use a pair of tweezers to peel back the tape covering the trackpad cable connector. Use a pair of tweezers to peel back the tape covering the trackpad cable connector.
    • Use a pair of tweezers to peel back the tape covering the trackpad cable connector.
  8. Use the pointed end of a spudger to lift up the small locking flap on the trackpad cable's ZIF connector. Use the pointed end of a spudger to lift up the small locking flap on the trackpad cable's ZIF connector.
    • Use the pointed end of a spudger to lift up the small locking flap on the trackpad cable's ZIF connector.
  9. Slide the microphone cable out of its connector. If possible, grip the cable by the tape, not by the cable itself.
    • Slide the microphone cable out of its connector.
    • If possible, grip the cable by the tape, not by the cable itself.
  10. Use a T5 Torx driver to remove the nine screws securing the trackpad:
    • Use a T5 Torx driver to remove the nine screws securing the trackpad:
    • Eight fully-coated 3.1 mm screws
    • One partially-coated 3.1 mm screw
  11. While keeping the laptop screen-side down, carefully open the laptop. The trackpad will stay sitting on the display. As you lift, make sure the trackpad cable threads through the opening on the case.
    • While keeping the laptop screen-side down, carefully open the laptop. The trackpad will stay sitting on the display.
    • As you lift, make sure the trackpad cable threads through the opening on the case.
  12. As you remove the trackpad assembly, be careful not to lose the five small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.) Remove the trackpad. Take extra care to not scratch the display.
    • As you remove the trackpad assembly, be careful not to lose the five small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Remove the trackpad.
    • Take extra care to not scratch the display.
  13. If your replacement trackpad comes with a trackpad cable preinstalled, this step isn't necessary. Use the flat end of a spudger to lift the small locking flap on the trackpad's ZIF connector. Slide the trackpad cable straight out of the ZIF connector.
    • If your replacement trackpad comes with a trackpad cable preinstalled, this step isn't necessary.
    • Use the flat end of a spudger to lift the small locking flap on the trackpad's ZIF connector.
    • Slide the trackpad cable straight out of the ZIF connector.
5 autres ont terminé cette réparation.
Carsten Frauenheim
Membre depuis le 10/03/2020
69 079 Réputation
330 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
140 membres
16 729 tutoriels rédigés
5 commentaires
Hi! So I successfully replaced my trackpad (the center screw got stripped so I had to use the superglue technique and threw it away), and the trackpad works perfectly well but without haptics. My replacement didn’t come with a new cable so used the old one after cleaning of the end (it had some blackening on the portion connected to the trackpad). Is my trackpad a bad unit or should I try replacing the cable first?
Tanmaya Mishra - Réponse
Hi! Considering the blackening on the old cable, I’d recommend thoroughly cleaning its contacts with high concentration (90%+) isopropyl alcohol and a Q-tip. Let it dry before reinstalling it. If that cleaning doesn’t help, replace the old cable before considering your replacement trackpad a bad unit. Good luck on your repair!
Carsten Frauenheim -
Hi Carsten! I tried cleaning it but didn’t work. Picked up a new cable from here, and now works flawlessly. Highly recommend anyone reading this to just buy a replacement cable too when you do the repair to rule out a faulty part. Thanks!
Tanmaya Mishra -
Hi, I replaced trackpad following the guide and trackpad seems to work but very slow and lagging. and when I log in, mac is showing message waiting for bluetooth trackpad to be discovered. Could this be cable issue?
ifixsmartphone - Réponse
Really thorough and easy to follow guide! Ordered the replacement parts after coffee spillage broke the previous trackpad and it's working a treat now, thanks!
Aamir Khan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 185
30 derniers jours : 835
Total : 7,055
