Introduction
Use this guide to replace a dead AirPort/Bluetooth card to regain Wi-Fi capability.
Ce dont vous avez besoin
Outil utilisé dans cette étape :P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
25 autres ont terminé cette réparation.
9 commentaires de tutoriel
Is tihs card is the same as in to Macbook Air 11 ?
is it possible to renew on of the two antenna cables, because mine get broken while lifting it
Did you ever find the cables for sale anywhere? Thanks.
