Aller au contenu principal
MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    J'achète
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Battery Connector: étape 3, image 1 de 2 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Battery Connector: étape 3, image 2 de 2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  4. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: étape 4, image 1 de 2 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: étape 4, image 2 de 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: étape 5, image 1 de 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: étape 6, image 1 de 2 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: étape 6, image 2 de 2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
31 autres ont terminé cette réparation.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
502 855 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
11 commentaires
Is it possible to replace 2012 wireless card to newer ac card?
Manoj Biswas - Réponse
^I have this same question
delgado1kevin - Réponse
Hello I just ordered a early 2013 Wifi/Bluetooth Macbook Air card that I will use to replace my current mid 2012 MacAir wifi/Bluetooth. I will keep everyone posted here. The card should arrive next week.
filipemiranda - Réponse
Did the 2013 AC airport card work on your 2012 macbook air?
Fritz Gamboa -
Yes it is. I got mine from WWW.QUICKERTEK.COM and it works perfectly. I can now use my Apple Watch to unlock my Mid 2012 MacBook Air 13"
Colin O'Neal - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 21
30 derniers jours : 66
Total : 26,521
