Introduction
Use this guide to replace a broken AirPort/Bluetooth card to get back your wireless.
Ce dont vous avez besoin
Outil utilisé dans cette étape :P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
31 autres ont terminé cette réparation.
11 commentaires de tutoriel
Is it possible to replace 2012 wireless card to newer ac card?
^I have this same question
Hello I just ordered a early 2013 Wifi/Bluetooth Macbook Air card that I will use to replace my current mid 2012 MacAir wifi/Bluetooth. I will keep everyone posted here. The card should arrive next week.
Did the 2013 AC airport card work on your 2012 macbook air?
Yes it is. I got mine from WWW.QUICKERTEK.COM and it works perfectly. I can now use my Apple Watch to unlock my Mid 2012 MacBook Air 13"
