Aller au contenu principal
Introduction
Use this guide to replace your Air's trackpad.
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
    Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
    allison - Réponse
    Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
    bwgvanderveer - Réponse
    I thought I could replace my 256 Gb SSD with 512? regards
    ola m - Réponse
    Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
    andrew - Réponse
    It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
    Larry Smith - Réponse
    tell a model that was not inferior to the speed of the one in the laptop.
    Thank you
    ilyabuhov - Réponse
    Do i need to order tools separately to replace the battery i just ordered?
    anne uhlir - Réponse
    im looking for a Logic Board for a
    Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
    Any help is appreciated.
    Jamie Comstock - Réponse
    P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
    William Skinner - Réponse
    I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
    eric -
    Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
    Dennis Eaton - Réponse
    My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
    Pennny Beach - Réponse
    The supplied kit and instructions worked perfectly!
    Nikolay Andreev - Réponse
    Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
    joemoog - Réponse
    Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
    Merci pour votre aide.
    chicco33 - Réponse
    oui, vous aurez besoin d’un adaptateur, pour completez le changement.
    Dan -
    The tool kit should include tweezers for re-inserting the battery connector.
    Andre Clement - Réponse
    P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
    michaelquinnell - Réponse
    Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
    Thomas Lewis - Réponse
    To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
    Pentalobe 1.2(mm)
    also
    P4 = 0.8
    P6 = 1.5
    Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
    nijafe -
    I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
    Sean Love - Réponse
    Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
    John Brennand - Réponse
    Just installed on a MacBookAir6,2 (13-inch, Early 2014).
    Was very easy.
    New iFixit battery looks great so far:
    Full Charge Capacity (mAh): 4922 -> 7333
    Jonathan Cross - Réponse
    can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
    hawk_lpc -
    Screw P5 Pentalobe 1.2
    Mario Verlent - Réponse
    Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
    Joel Sebastian - Réponse
    Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
    Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
    Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
    Donald Niamath - Réponse
    Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
    Amir Zaidi - Réponse
    Thank you very much for the guilde. My MBA2011 had reborn !
    Billy Wong - Réponse
    Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
    See great advice: Electrostatic Discharge
    Fletcher Cole - Réponse
    … und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
    ... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
    Blatt - Réponse
  1. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
    Jeannie Crowley - Réponse
    To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
    nijafe -
    When closing this back up make sure that the antenna cable is tucked away neatly
    Gabriel - Réponse
    So this is a legit back cover for MacBook Air?
    ASHANTI SMITH - Réponse
    What about disconnecting the battery?
    Luke Grimes - Réponse
    I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
    Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
    Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
    Lance Berc - Réponse
    As noted by others, be a bit careful removing the lower case. There is an oblong black plastic locator very near the center of the lower case. Unless you gently pry the bottom cover pretty much straight up, you will break the ends off of the locater.
    BobY - Réponse
  2. Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board. Do not lift upward on the connector as you disconnect it.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
    The guide says: "Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board", but the battery model that I was replacing did not have a clear plastic pull tab at all...
    The battery model shown in this guide is: A1405
    I was installing battery model: A1406
    A1406 has the following connector:
    Top:
    http://www.directupload.net/file/d/4122/...
    Bottom:
    By looking at the bottom of the new battery I saw how it could be removed. Simply by a gentle upward movement. I very, very carefully nudged it a bit upwards using a screwdriver on the left and right side, as shown here:
    It came out fairly easy, luckily!
    (And yes, I also cleaned up this MacBook before closing it again. It was a bit hairy in a literal way. Electronics and pets is not the best combination. ;-) )
    This was a great guide!
    wil - Réponse
    I think you may have been reading the wrong guide by mistake.
    Looking at the various MacBook Air battery replacement guides, all of the 13" models show the connector depicted in this guide. All of the 11" models (e.g. Remplacement de la batterie du MacBook Air 11" mi-2012) show a connector like the one in your photos.
    shamino -
    The 13 inch's tab is a bit more difficult to reinstall than uninstall. Delicate care is needed.
    Andrew Ruble - Réponse
    I agree with Andrew and Joes. I also found that the trickiest part was to pull the tap back when reinstalling the new battery. A special hint at this point in the guide would be nice.
    Alexander Kluge -
    This is the tricky part if there is one. Just pull back towards the battery and not up.
    Joe Wasser - Réponse
    hello there, My macbook air does not recognize a battery connected, anymore.
    It looks like I damaged the connectors while trying to connect the battery back, although it does not look damaged. I must say, I tried a little force to squeeze the connector in the middle instead of the edge. May have damaged the connector ?
    Once, after this, the MBA recognized my battery when pressed the connectors edge to the pins on the board. However, this did not last long and my MBA does not recognize the battery anymore. Any solutions on how I can fix this ? Please help.
    Samy Palaniappan - Réponse
    Had the same issue where my Macbook did not recognize the battery on the first try. I opened it back up and re-seated the connector and that fixed the problem. That particular connector does not seem to have a positive engagement. It does not appear to seat all the way down. It’s charging now and I hope it will remain stable and connected as I travel.
    Paul Tornatta - Réponse
    When we were putting the new battery in, it was easier to fit the tab back on and then fit the battery in place. I had someone helping me and they held the new battery up whilst I pushed the tab in. It was quite tight, and I ended up easing it in with the tip of a screwdriver on each edge in turn.
    Shimbo - Réponse
    The plastic pull tab broke off with the tiny tug I gave it (Mid-2011 Air). I just unscrewed the battery and carefully pulled out the connector when I had the extra room.
    Sam Kernot - Réponse
    for my 11inch mac air [mid 2011] the connecter is connected vertically and not horizontally - so you need to pull up, not back. thanks to Will for the links to the illustrations that made that clear. Getting the connecter to release was the hardest part of the job - otherwise, it was just removing screws.
    Jim Kemper - Réponse
    I had same as above you have to be very sure on your screen size as the battery disconnect looks a little different and I used the 11 inch steps on the link provided which worked perfectly! thanks
    Jim Lukens - Réponse
    Successful battery change on Macbook Air 13 mid-2012.
    After screwing in the new battery, I couldn't connect it to the motherboard. I was afraid of damaging the connection and the rest of the components.
    So it seemed easier to me to unscrew the new battery, then plug it in and finally screw it back in one last time. I think that this step lacks a point of precision in terms of reassembly.
    Otherwise, it's a good tutorial, thank you very much!
    Steve Baudron - Réponse
    **Note during this step how the cable flexes. With the new battery you will need to carefully bend your new connector to be able to flex in the same way, which is easier to do before you install the battery. in fact, i agree with other comments that for re-install it is easier carefully hold the battery up a bit (to keep it off the trackpad components), and install the plug as you are moving the battery up into place. This will limit the amount the cable needs to flex and take that pressure off the connector to the logic board.
    llcoreyll - Réponse
    In line with some other comments, I found it helpful to connect the cable before putting the new battery into place. That way I could aim the cable straight into the receptacle, and the wires folded appropriately into their small space when I put the battery in position and screwed it down.
    Katherine Williams - Réponse
  3. Remove the following five screws securing the battery to the upper case:
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
    Les couleurs ne me semblent pas justes.
    drixe - Réponse
    The screw heads are made of a soft butter like chinese metal and will easily get f*cked up. take care when reinstalling to not mess them up.
    John Hamilton - Réponse
    les couleur sont justes; die rot markierten Schrauben oben und mitte sind länger als die unteren.
    I had used the P5 driver there, too (just gently put the bit into the screws and see that’ll fit.
    jmhoraze - Réponse
    The battery doesn’t actually need to come out for this repair if you’re confident working in tight spaces.
    J Kemp - Réponse
    Ich habe ein Problem die Schrauben von dem Akku mit dem gelieferten Schraubenzieher-Set rauszudrehen. Nur die Schraube in der Mitte konnte ich rausdrehen. Brauche ich einen anderen Schraubenzieher? Sollen die beiden Schraubenzieher aus dem mitgelieferten Set zu den Akku-Schrauben passen? Danke für eure Hilfe im Voraus! Alex
    Alex - Réponse
    Ich habe das Problem gelöst! Akku ist eingebaut. Mein Mac Air läuft wieder!
    Danke!
    Alex
    Alex - Réponse
  4. When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • When installing the new battery, if there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    Quick note about the replacement battery, if you bought from iFixit and the battery sections have a thin film over them, peel them off. They're to protect the battery during transit, and if you leave them on they might cause heating issues.
    Here is a link to my question about it: Replacement battery has thin film on each section do I need to remove? plus, I just got an email from iFixit customer support that it needs to be removed.
    dpchoung - Réponse
    thank you for the help! I installed the proper batt properly following the advice from here;-) Mahalo from Hawaii-
    zzzikaikazzz - Réponse
    Does replacement battery for Macbook Air 13" Mid 2012 works with Mac OS Sierra 10.12.3 and up?
    Benny Forsberg - Réponse
    I installed the battery (OEM Apple) for the Mac Air 2013 throygh 2015:
    1. the battery for the Mac Air 2012 throygh 2015 was stated to may have compatibility problems;
    2. lesser price;
    no problems with macOS Sierra.
    jmhoraze - Réponse
    Replaced it in no time! Thank you and cheers from Slovenia (that’s the one who beat you in hockey few days ago
    Mark Ogner - Réponse
    iFixit should really clarify whether the film covering each of the battery packs should or should not be removed. Based on dpchoung’s comment I removed this film. It was not obvious or easy to remove and as I was doing it I realized that maybe this was not a good idea as I was concerned the packs might be damaged in the removal process. I suspect most people don’t bother with this film. Later, clicking on the forum exchange I see conflicting advice. My guess is that the film provides added protection and has minimal impact on thermal issues. I am sorry I went through the bother of removing the film and hope no damage was done.
    Mark Young - Réponse
    Ich hab’ gelesen, dass neu eingebaute Batterien kalibriert werden müssen: https://www.newertech.com/batteries/powe...
    hjsalchow - Réponse
    Step 1 has an error, at least for me. I believe the 10 pentalobe screws are size P4, not P5. My Wiha P5 pentalobe screwdriver was too big for the screws, but my smaller P4 pentalobe screwdriver worked fine.
    BrianM - Réponse
    Great here. Replacement was a breeze. Thanks guys.
    DanielFerrer - Réponse
    Why should I wait 5 hours after draining the battery before charging it again?
    thomas.ss - Réponse
    It’s part of the calibration process—leaving it dead for awhile ensures that the battery drains low enough to reset the full discharge flag in the battery management system. If you skip that part, your battery may not calibrate properly. (It’ll still work fine, but the battery’s % charge status in macOS may be unreliable and/or behave in odd ways.) If you had to skip it for some reason, you can recalibrate at any time.
    Jeff Suovanen -
    After I replaced the battery, I plugged the charger in to start calibration and the computer started by itself. As soon as this happened I turned it off. Can this be an issue?
    How do I know the battery is 100% charged?
    Thank you
    tobias.a94 - Réponse
    It might be obvious to most people, but no mention of plugging in the battery connector when installing the new battery. I missed that part at first. Overall great instructions and finished quickly.
    Staci Thompson - Réponse
    It went well, thank you. One comment though, I prefer to put the connector back before installing the new battery since the cable is not flexible enough.
    ricochapuis - Réponse
    Replaced my new battery for a mid 2011 MacBook Air but now the battery icon says it’s not charging
    Mike Bridgewater - Réponse
    how do i dispose of the old battery responsibly?
    Jonathan Peters - Réponse
    Why shouldn’t I touch the lithium polymer cells? Is that on removal, too? Is it dangerous for me or just the battery (like getting finger oils on a halogen bulb)? Would it be beneficial to wear thin latex gloves?
    Andrew Greenseid - Réponse
    After Installation my MacBook does not start, but there are peep tones 3x in a row and this repeats until I press power for few seconds. Any clue what this could be?
    b.winkler343 - Réponse
    Installation was very easy. Works perfect for me and battery is now fully charged and running.
    Andreas Otte - Réponse
    Installation was a breeze thanks to your tips.
    KAT VELASQUEZ - Réponse
  5. Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap (on the side opposite the cable), not the socket itself.
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap (on the side opposite the cable), not the socket itself.
    • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
    Thanks for this fantastic guide!!! Got an old Macbook Air working again. Only difficult spot was the ZIF cables. Man, I hate ZIF cables....
    lyleberman - Réponse
    I found it easyer to first connect the cables to the touchpad during reassabling. I could handel the tiny connectors better. After connecting the cabels I could easiely install the touchpad it self.
    Stefan Kania - Réponse
  6. While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
  7. Remove the following twelve screws:
    • Remove the following twelve screws:
    • Six 1.6 mm Phillips screws securing the trackpad to the upper case.
    • Six 1.6 mm Phillips screws securing the trackpad brackets to the trackpad.
    • A Phillips #000 should be sufficient, but a JIS #000 may also work as well.
    I stripped one of the six 1.6mm screws securing the trackpad to the upper case. Where could I get a replacement and what are the exact dimensions (I assume that 1.6mm is the length not the head size). Not sure whether this is the right place to post this, but I would be very thankful for some help.
    Karl - Réponse
    The 00 philips driver is not working for these 6 screws...very frustrated....
    Adam - Réponse
    The 00 phillips screw driver does not do the job for step 8!!!!!!!!! FRUSTRATING!
    anonymous 1446 - Réponse
    Anyone figured the right screwdriver?
    er09gi4v - Réponse
    Worst part was the philips screws on the brackets, step 8. One screw wouldn't unscrew for the longest time. I stripped it so bad, that I finally got it undone with a Torx 5 that I wedged into the stripped screw hole! Fortunately the replacement trackpad came with it's own brackets and screws anyway, so I didn't need to re-use the messed up screw.
    In the end, success...phew!
    fauxryan - Réponse
    Beware that when you remove these screws the trackpad will have dropped down and resting on the screen. Maybe a precaution would be to place a thin cloth between the trackpad and screen.
    Joe - Réponse
    Agreed on the error in the guide. J00 seems to be the best fit.
    H4nd5omeR0b - Réponse
    I stripped one of the 12 screws. Of course one of the ones attached to the unibody frame not the trackpad. I thought I could weasel the trackpad out without taking the right bracket off but no dice. I had to bend the bracket and turn it around to get the trackpad out.
    After I got the trackpad out I took out the replacement (purchased from here) and lo and behold it had the two brackets attached! So great, I'm good on screw count! But crap, now I REALLY need to get that stripped screw back out.
    Thankfully I was able to dig it out with a tiny flat head bit from the 54 bit driver kit.
    I even reattached the two brackets to the old trackpad and put it back in the ESD bag. I wonder if I can send it back to iFixIt to be refurbished. Don't want to toss it and have it wind up in a landfill unnecessarily!
    David Lam - Réponse
    The Phillips 00 I bought from iFixit definitely doesn't work. Gonna try their 000.
    jorach - Réponse
    My new trackpad came with the brackets installed. It wasn’t necessary for me to remove the screws circled in orange (they hold the bracket to the trackpad). Check to see if your new trackpad has the brackets installed before removing the orange screws.
    Doug Weathers - Réponse
    After purchasing multiple sets of drivers to get these out, I recommend anyone who finds they don’t have an adaquet PH00 driver to skip any dollar store or RadioShack driver sets. Head down to your local tool shop or auto repair store and buy yourself a $5-$10 set of precision drivers with only a few bits. Don’t go buying yourself a 20 piece set and think you’re getting a deal, these screws require a good quality PH00 to be removed without stripping.
    Spencer Shupe - Réponse
    When you're putting it back together, it's useful to attach these to the trackpad so it won't drop below the socket
    Jelan - Réponse
    Removing the bracket is completely unnecessary. Simply remove the top three screws on each bracket, and slide the trackpad out.
    Kit - Réponse
  8. Remove the right and left trackpad brackets  from the upper case.
    • Remove the right and left trackpad brackets from the upper case.
  9. Remove the 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
    • Remove the 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
    • During reassembly, do not over-tighten the set screw, as the button will cease to click at a certain point. Adjust the set screw until the movable side of the trackpad has minimal play.
    This was a T10 on my Mid 2011.
    Joe - Réponse
    Sorry, seems more like a T6
    Joe -
    This was a T6 on mine as well. Sadly I figured that out after threading the screw with the T5 included in the iFixit kit, so now my trackpad won't click at all.
    IMPORTANT NOTE: Buy a T6 screwdriver if the T5 in the kit is just a bit too small for the screw in step 10.
    Jon -
    I thought the purpose of this set screw was to adjust the height of the pad relative to the rest of the deck. By feeling underneath as I adjusted this screw, I was able to get the join between the pad and the deck seamlessly level,
    bbc2 - Réponse
    Hi, I just want to ask what it means that it will stop clicking eventually, I had my macbook air trackpad replaced after some water fell on it and now around 9 months later the trackpad click gets stuck and it's driving me crazy, I went back to the service center myself and the technician actually admitted that he overtightened the screws but since the parts warranty is only 90 days he has to charge me again. So my question actually is can overtightening it cause permanent damage? Is there anything I can do? There's no apple store here (Cyprus) but the service center is one of the official service and registered distributor for Mac products and specifically for the more professional clientele.
    crossmission1984 - Réponse
    can anyone tell me where to get a replacement for the set screw mentioned in step 10? mine has gone missing. all i need is the screw, i don't want to replace the whole trackpad.
    sean - Réponse
    I, too, have a question about the set screw. I replaced a MacBook Air 2011 keyboard because of water damage and that process involves also taking out the trackpad and putting it back in. After reassembly, I now get phantom clicks (the "click" sound happens as expected, but the Air frequently thinks I'm clicking when I'm not). Could this be a result of over/under tightening the set screw, or is it more likely the trackpad also needs replacement?
    Hank - Réponse
    The set screw on my macbook barely turns 1/8 of a rotation before it hits a blockage. I do not want to try to turn harder for fear of stripping the screen and/or the threads in the case. I assumed that the screw should be able to be completely unscrewed from the case, correct? Any idea what's causing the blockage?
    johnkowtko - Réponse
    There is no need or benefit to removing this screw completely. Maybe back it out a little bit just to make it easier to install the new trackpad, and then adjust it once the new trackpad is mounted in the case. Agreed, this was a T6 on my MacBook Air 13" Mid 2012.
    mattdittrich - Réponse
    It was a T6 in MacBook Air Mid 2011 as well.
    Armin Hempel - Réponse
    Touching this screw is unnecessary.
    Kit - Réponse
  10. Use the flat edge of a spudger to carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case. Remove the trackpad from the upper case.
    • Use the flat edge of a spudger to carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
    • Remove the trackpad from the upper case.
42 autres ont terminé cette réparation.
Andrew Optimus Goldheart
Membre depuis le 17/10/2009
474 296 Réputation
410 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
137 membres
16 428 tutoriels rédigés
i have problems with reassembly. how do i manage it to get the keyboard connector in the socket again? i can't make enough pressure to get it in
Peter - Réponse
Hey guys,
just repaired my "old" 2012 Air's touchpad and thanks to your great instruction it took me exactly 30 Mins and was super easy...
Thanks for your great work!
@peter: yes, it needs a bit fiddling with the cables - just keep an eye on the flaps (they are closed on the new TP). Then it helped me to press the cable slightly in place with one hand and carefully pushing it in (moving it slightly left and right) with the other.
Patrick Maier - Réponse
Great guide!! recently repaired two mb air of my office, great parts!!! great guide
Miguel Cartagenova - Réponse
step 10 is not needed, in my second repair of this model I didn't remove it, this screw is only for calibration
Right. Step 10 is not only not needed but should definitely not be done! This is a pure adjustment screw for the clickpoint. Only readjust there, in case clicking does not feel okay after a change of the trackpad. Usually no adjusment is necessary.
Marc Malkwitz - Réponse
I found a phillips #00 worked better on step 8. I striped one of the screws with the #000.
ilikecats - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 41
30 derniers jours : 165
Total : 33,394
