Introduction
Utilisez ce tutoriel pour remplacer le pavé tactile.
Avant de commencer, éteignez votre appareil. Fermez l'écran et posez-le à l'envers sur une surface douce.
  • Avant de commencer, éteignez votre appareil. Fermez l'écran et posez-le à l'envers sur une surface douce.
  • Retirez les dix vis suivantes :
    • Deux vis Pentalobe P5 9 mm
    • Huit vis Pentalobe P5 2.6 mm
  • Vous trouverez ici le tournevis spécial dont vous aurez besoin pour enlever les vis Pentalobe.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Réponse
My Wiha P5 screwdriver was too big for these screws, but my P4 worked fine.
BrianM -
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Réponse
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Réponse
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Réponse
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Réponse
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Réponse
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Réponse
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Réponse
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Réponse
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Réponse
P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
William Skinner - Réponse
Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
Dennis Eaton - Réponse
Mettez vos doigts entre l'écran et le boîtier inférieur et tirez vers le haut pour détacher le boîtier inférieur.
  • Mettez vos doigts entre l'écran et le boîtier inférieur et tirez vers le haut pour détacher le boîtier inférieur.
  • Enlevez la partie inférieure et mettez-la de côté.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Réponse
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Réponse
  • Saisissez la petite languette en plastique transparent attachée au connecteur de la batterie, et tirez-la vers l'avant du MacBook Air pour déconnecter la batterie de la carte mère.
  • Ne tirez pas le connecteur vers le haut en le déconnectant.
Ajouter un commentaire
  • Dévissez les cinq vis suivantes, fixant la batterie au boîtier supérieur :
    • Trois vis Torx T5 de 6,3 mm
    • Deux vis Torx T5 de 2,4 mm
When going in reverse, it's easier to do step 3 before 4.
John Heffernan - Réponse
  • En manipulant la batterie, évitez de presser ou de toucher les 4 cellules lithium-polymère apparentes.
  • Soulevez la batterie par les bords du côté de la carte mère et retirez-la ensuite du boîtier.
  • Si vous installez une nouvelle batterie :
    • Calibrez votre batterie avant de l'utiliser : laissez-la se vider toute la nuit, puis chargez-la à 100% et videz-la à nouveau jusqu'à ce que votre MacBook Air s'éteigne automatiquement. Chargez-le à nouveau et utilisez-le normalement.
    • Si vous remarquez un comportement inhabituel ou des problèmes après l'installation de votre nouvelle batterie, vous devrez peut-être réinitialiser le contrôleur de gestion du système (SMC) de votre MacBook Pro.
  • Utilisez la pointe d'un spudger ou votre ongle pour retourenr le clapet de retenue de la prise ZIF de la nappe du pavé tactile.
  • Assurez-vous de faire levier sur le clapet de retenue articulé et non sur la prise même.
  • Tirez la nappe du pavé tactile tout droit hors de sa prise, vers le bord arrière de l'Air.
  • Tout en soulevant soigneusement la nappe du clavier d'une main, utilisez la pointe d'un spudger ou votre ongle pour retourner le clapet de retenue de la prise ZIF de la nappe du clavier.
  • Tirez la nappe du clavier tout droit hors de sa prise, vers le bord avant de l'Air.
the trickiest step on re-assembly is reinserting this back-folded cable into the socket and then making sure the retaining flap (now hidden) is firmly down again. You can tell if it is still up (and so the cable loose) if the cable does not feel flat when you run your finger lightly over it.
Jon May - Réponse
  • Retirez les douze vis suivantes :
    • Six vis cruciformes de 1,6 mm fixant le pavé tactile au boîtier supérieur.
    • Six vis cruciformes de 1,6 mm fixant les dispositifs de support du pavé tactile au pavé.
  • Retirez du boîtier supérieur les dispositifs de support droit et gauche du pavé tactile.
on re-assembly, having the front open slightly so that I could put some pressure on the other side of the trackpad behind the holes for the screws made it easier to reseat them
Jon May - Réponse
  • Retirez la vis T5 Torx de 1,4 mm de son trou près du bord avant du boîtier supérieur.
  • Lors du remontage, ne serrez pas trop la vis de réglage, car le bouton finit par arrêter de cliquer. Ajustez la vis de réglage jusqu'à ce que le côté de clic du pavé tactile ait un jeu minimal.
  • Utilisez l'extrémité plate d'un spudger pour faire soigneusement levier sur le bord du pavé tactile le plus proche du clavier et l'enlever de son emplacement dans le boîtier supérieur, en l'écartant des dispositifs de support fixés au boîtier supérieur.
  • Retirez le pavé tactile du boîtier supérieur.
if you open the front case slightly at this point a little pressure on the trackpad helps to lift it - but just a millimetre or two.
Jon May - Réponse
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
18 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
90%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Great write up. Where can I find the keyboard ribbon cable? (the wide one that doesn't make any 90s. I tore mine with metal tweezers. Can't find the wide cable anywhere.
ahaffke - Réponse
shhhhh, it's called ie bAe eYe
emaginechild -
even a 65 year old can do it! (with magnifying glasses) Thank! Fixed the dirty, sticking trackpad!
Scott Salling - Réponse
Step 10 should not be done! This is a pure adjustment screw for the clickpoint. Only readjust there, in case clicking does not feel okay after a change of the trackpad. Usually no adjusment is necessary. The trackpad comes out easily after Step 8
Schritt 10 ist falsch! Diese Schraube dient lediglich der Justage des Druckpunkts des Klicks. Sie muss nur verstellt werden, falls der Klick nach dem Wechsel des Trackpads nicht mehr ok ist. Das Trackpad lässt sich aber bereits nach Schritt 8 problemlos entnehmen.
Marc Malkwitz - Réponse
Voir les statistiques:
Dernières 24 heures : 23
7 derniers jours : 111
30 derniers jours : 472
Total : 23,758
