Aller au contenu principal
MacBook Air 15" 2024 Touch ID Sensor Replacement
Ce dont vous avez besoin
  1. MacBook Air 15" 2024 Touch ID Sensor Replacement, Prepare your Macbook Air for disassembly: étape 1, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Prepare your Macbook Air for disassembly: étape 1, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Prepare your Macbook Air for disassembly: étape 1, image 3 de 3
    • Allow your MacBook's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully power off your MacBook.
    • Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
  2. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the lower case: étape 2, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the lower case: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    FixMat
    $31.41
    • Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
  3. MacBook Air 15" 2024 Touch ID Sensor Replacement, Insert an opening pick: étape 3, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Insert an opening pick: étape 3, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Insert an opening pick: étape 3, image 3 de 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 15" 2024 Touch ID Sensor Replacement, Release the snapping clips: étape 4, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Release the snapping clips: étape 4, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Release the snapping clips: étape 4, image 3 de 3
    • During the next two steps you'll feel and hear six snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. MacBook Air 15" 2024 Touch ID Sensor Replacement: étape 5, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement: étape 5, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement: étape 5, image 3 de 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. MacBook Air 15" 2024 Touch ID Sensor Replacement, Release the sliding tabs: étape 6, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Release the sliding tabs: étape 6, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Release the sliding tabs: étape 6, image 3 de 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat to the frame and firmly slide it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the lower case: étape 7, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the lower case: étape 7, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the lower case: étape 7, image 3 de 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the battery connector cover tape: étape 8, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the battery connector cover tape: étape 8, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the battery connector cover tape: étape 8, image 3 de 3
    • Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
    • During reassembly, use the leftover adhesive to secure the tape to the cover.
  9. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the battery connector cover: étape 9, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the battery connector cover: étape 9, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the battery connector cover: étape 9, image 3 de 3
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
    • Remove the cover.
  10. MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the battery: étape 10, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the battery: étape 10, image 2 de 2
    • Use an opening pick to pry up and disconnect the battery connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the speaker cable and hinge covers: étape 11, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the speaker cable and hinge covers: étape 11, image 2 de 2
    • The right speaker will be on your left-hand side when working on the MacBook, as it's laying upside down.
    • Use a 3IP Torx Plus screwdriver to remove the following screws:
    • Two 2.6 mm‑long screws securing the left hinge cover
    • Two 1.5 mm‑long screws securing the speaker cable cover
  12. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the covers: étape 12, image 1 de 1
    • Remove the speaker cable cover.
  13. MacBook Air 15" 2024 Touch ID Sensor Replacement: étape 13, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement: étape 13, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement: étape 13, image 3 de 3
    • Insert the point of a spudger into one of the left hinge cover's screw holes.
    • Push the hinge cover away from the back edge to dislodge it.
    • Remove the hinge cover.
  14. MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the right speaker: étape 14, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the right speaker: étape 14, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the right speaker: étape 14, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the right speaker press connector.
  15. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the right speaker: étape 15, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the right speaker: étape 15, image 2 de 2
    • Remove the three screws securing the right speaker:
    • One 5.5 mm‑long 4IP Torx Plus screw
    • One 2.7 mm‑long 4IP Torx Plus screw
    • One 3.5 mm‑long 6IP Torx Plus screw
  16. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the right speaker: étape 16, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the right speaker: étape 16, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the right speaker: étape 16, image 3 de 3
    • Make sure the cable on the top right edge of the speaker doesn't get caught on the logic board, as it may tear.
    • Lift the speaker's left edge over the frame and slide it to the left to remove it.
    • During reassembly, slide the speaker cable under the left edge of the antenna bar assembly before laying the speaker in its recess.
  17. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the speaker cable and hinge covers: étape 17, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the speaker cable and hinge covers: étape 17, image 2 de 2
    • The left speaker will be on your right-hand side when working on the MacBook, as it's laying upside down.
    • Two 2.6 mm‑long screws securing the right hinge cover
  18. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the covers: étape 18, image 1 de 1
  19. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the right hinge cover: étape 19, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the right hinge cover: étape 19, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the right hinge cover: étape 19, image 3 de 3
    • Insert the point of a spudger into one of the right hinge cover's screw holes.
  20. MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the left speaker: étape 20, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the left speaker: étape 20, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the left speaker: étape 20, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the left speaker press connector.
  21. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the left speaker: étape 21, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the left speaker: étape 21, image 2 de 2
  22. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the left speaker: étape 22, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the left speaker: étape 22, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the left speaker: étape 22, image 3 de 3
    • Make sure the cable on the top left edge of the speaker doesn't get caught on the logic board, as it may tear.
    • Lift the speaker's right edge over the frame and slide it to the right to remove it.
    • During reassembly, slide the speaker cable under the right edge of the antenna bar assembly before laying the speaker in its recess.
  23. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the antenna cables cover: étape 23, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the antenna cables cover: étape 23, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the antenna cables cover: étape 23, image 3 de 3
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the antenna cables cover.
    • Remove the cover.
  24. MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the antenna bar: étape 24, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the antenna bar: étape 24, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the antenna bar: étape 24, image 3 de 3
    $3.99
    • Insert one arm of a pair of angled tweezers under the metal neck of one of the antenna connectors and lift straight up to disconnect it.
    • Disconnect the other antenna.
    • To reconnect antenna connectors, hold each one in place over its socket and press down with the flat end of your spudger. The connector will snap into place.
  25. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the antenna bar: étape 25, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the antenna bar: étape 25, image 2 de 2
    • Use a 4IP Torx Plus screwdriver to remove the two 5.5 mm‑long screws securing the antenna bar.
  26. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the antenna bar: étape 26, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the antenna bar: étape 26, image 2 de 2
    • Remove the antenna bar.
  27. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the foam pad: étape 27, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the foam pad: étape 27, image 2 de 2
    Tesa 61395 Tape
    $2.99
    • A foam pad hides two screws securing the display and camera cables cover. It's secured with light adhesive.
    • Use tweezers or your fingers to remove the foam pad from the cover.
    • During reassembly, use the leftover adhesive to secure the pad. If the pad doesn't stick, use double-sided tape to secure it.
  28. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the cables cover: étape 28, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the cables cover: étape 28, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the cables cover: étape 28, image 3 de 3
    • Use a 3IP Torx Plus screwdriver to remove the four 1.5 mm‑long screws securing the display and camera cables cover.
    • Remove the cover.
  29. MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the display and camera: étape 29, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the display and camera: étape 29, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the display and camera: étape 29, image 3 de 3
    • Use a spudger to pry up and disconnect the display and camera cable press connectors.
  30. MacBook Air 15" 2024 Touch ID Sensor Replacement, Reassembly information: étape 30, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Reassembly information: étape 30, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Reassembly information: étape 30, image 3 de 3
    • During reassembly, use the flat end of a spudger to gently push the display and camera cables under the logic board.
  31. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the display and camera cables: étape 31, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the display and camera cables: étape 31, image 2 de 2
    • Use a 3IP Torx Plus screwdriver to remove the two 2.8 mm‑long screws securing the display and camera cables to the frame.
  32. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the cover tape: étape 32, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the cover tape: étape 32, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the cover tape: étape 32, image 3 de 3
    • Use blunt nose tweezers or your fingers to remove the foam pad and two pieces of tape:
    • The headphone jack press connector cover's foam pad
    • The trackpad cable tape
    • The MagSafe and Thunderbolt connector cover tape
    • During reassembly, use the leftover adhesive to secure the foam pad and pieces of tape.
  33. MacBook Air 15" 2024 Touch ID Sensor Replacement, Separate the trackpad cable adhesive: étape 33, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Separate the trackpad cable adhesive: étape 33, image 2 de 2
    Tesa 61395 Tape
    $2.99
    • Light adhesive secures the trackpad cable to its metal cover.
    • Pull the trackpad cable away from its cover to separate the adhesive securing it.
    • During reassembly, use the leftover adhesive to secure the trackpad cable to the cover. If the cable doesn't stick, use double-sided tape to secure it.
  34. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the connector covers: étape 34, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the connector covers: étape 34, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the connector covers: étape 34, image 3 de 3
    • Use a 3IP Torx Plus screwdriver to remove the six 1.5 mm‑long screws securing the interconnect, trackpad, and MagSafe/Thunderbolt connector covers.
    • Remove the three connector covers.
  35. MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the logic board cables: étape 35, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the logic board cables: étape 35, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the logic board cables: étape 35, image 3 de 3
    • Use a spudger to pry up and disconnect all seven press connectors from the logic board:
    • One for the interconnect cable
    • One for the trackpad cable
    • One for the microphone array cable
    • Four on the right side of the logic board for the MagSafe, Thunderbolt and Hall effect sensor cables
  36. MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the logic board: étape 36, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Unfasten the logic board: étape 36, image 2 de 2
    • Use a 3IP Torx Plus screwdriver to remove the two screws on the upper left edge of the logic board:
    • One 2.6 mm‑long screw
    • One 4.7 mm‑long screw
    • Use a 5IP Torx Plus screwdriver to remove the six remaining screws securing the logic board:
    • Three 3.1 mm‑long screws
    • Two 3.8 mm‑long screws
    • One 3.6 mm‑long screw
  37. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the logic board: étape 37, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the logic board: étape 37, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the logic board: étape 37, image 3 de 3
    • Grip the right side of the logic board and remove it.
    • Lower the logic board into place, making sure no cables get stuck underneath.
    • Carefully check the edges of the logic board to see if any cables got stuck underneath. If any did, use the point of a spudger to gently pull them out.
  38. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the connector covers: étape 38, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the connector covers: étape 38, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the connector covers: étape 38, image 3 de 3
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the Touch ID sensor and headphone jack connector covers.
    • Remove the two covers.
  39. MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the Touch ID sensor: étape 39, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Disconnect the Touch ID sensor: étape 39, image 2 de 2
    • Use a spudger to pry up and disconnect the Touch ID sensor press connector from the daughterboard.
  40. MacBook Air 15" 2024 Touch ID Sensor Replacement, Separate the cable adhesive: étape 40, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Separate the cable adhesive: étape 40, image 2 de 2
    Tesa 61395 Tape
    $2.99
    • Light adhesive secures the Touch ID sensor cable to the frame.
    • Use blunt-nose tweezers or your fingers to peel the Touch ID sensor cable from the frame.
    • If your new Touch ID sensor's cable comes with adhesive, remove the plastic liner and press the cable into place on the frame.
    • If the cable doesn't have adhesive, use a strip of double-sided tape to secure it to the frame.
  41. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the Touch ID sensor bracket: étape 41, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the Touch ID sensor bracket: étape 41, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the Touch ID sensor bracket: étape 41, image 3 de 3
    • Use a 3IP Torx Plus screwdriver to remove the six screws securing the Touch ID sensor and its bracket:
    • Four 2 mm‑long screws
    • Two 1.7 mm‑long screws
    • Install the screws without fully tightening them.
    • Open your MacBook and align the Touch ID sensor on the keyboard.
    • Close your MacBook and fully tighten the screws.
  42. MacBook Air 15" 2024 Touch ID Sensor Replacement, Open your MacBook: étape 42, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Open your MacBook: étape 42, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Open your MacBook: étape 42, image 3 de 3
    • Open your MacBook until the main body stands up on its own.
  43. MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the Touch ID sensor: étape 43, image 1 de 2 MacBook Air 15" 2024 Touch ID Sensor Replacement, Remove the Touch ID sensor: étape 43, image 2 de 2
    • Pull the Touch ID sensor away from the frame while guiding the cable through its slot.
    • Remove the sensor.
  44. MacBook Air 15" 2024 Touch ID Sensor Replacement, Reassembly information: étape 44, image 1 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Reassembly information: étape 44, image 2 de 3 MacBook Air 15" 2024 Touch ID Sensor Replacement, Reassembly information: étape 44, image 3 de 3
    • Guide the new Touch ID sensor's cable through its slot in the fame.
    • Make sure the cable is properly oriented so the press connector lines up with its socket.
    • Hold the cable with one hand and use your other hand to align the new sensor in its recess.
    • Once the sensor is aligned, gently pull the cable away from the MacBook to secure the sensor against the frame.
    • Continue holding the sensor in place by its cable and slowly close the MacBook.
Spencer Day
Membre depuis le 09/14/22
149 272 Réputation
995 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 608 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 49
Total : 584
