Aller au contenu principal
MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement
Ce dont vous avez besoin
  1. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement, Lower Case: étape 1, image 1 de 1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 2, image 1 de 2 MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 2, image 2 de 2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement, Battery: étape 3, image 1 de 1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 4, image 1 de 1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 5, image 1 de 1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement, Speaker: étape 6, image 1 de 1
    • Remove the following two screws securing the speaker assembly to the upper case.
    • One 3 mm Phillips.
    • One 5.8 mm Phillips.
  7. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 7, image 1 de 2 MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 7, image 2 de 2
    • Use a spudger to lift the audio-out connector board off the adhesive that secures it to the hard drive bracket.
    • Disconnect the audio out connector from its socket.
  8. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 8, image 1 de 2 MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 8, image 2 de 2
    • Rotate the speaker assembly toward the center of the Air.
    • Use a spudger to pry the speaker cable connector up off the audio board.
  9. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement, Port Hatch Assembly: étape 9, image 1 de 2 MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement, Port Hatch Assembly: étape 9, image 2 de 2
    • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
    • If necessary, pull the audio out ribbon cable off the adhesive securing it to the upper case.
  10. MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 10, image 1 de 2 MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement: étape 10, image 2 de 2
    • Remove the four 3.2 mm Phillips screws securing the port hatch assembly to the upper case.
    • Lift the port hatch assembly out of the upper case.
7 autres ont terminé cette réparation.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 25
Total : 15,451
